cgal-discuss - Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • To:
  • Subject: Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • Date: Wed, 20 Jun 2012 17:27:55 +0200
I cleared all the previously generated Cmake related files. Then I ran the
cgal_create_cmake_script and then what you suggested:
> "cmake -DEIGEN3_INCLUDE_DIR=/Users/drorata/Library/eigen3.1.0-rc1 ."
This was the output:
---(Output)---
-- The C compiler identification is GNU 4.2.1
-- The CXX compiler identification is GNU 4.2.1
-- Checking whether C compiler has -isysroot
-- Checking whether C compiler has -isysroot - yes
-- Checking whether C compiler supports OSX deployment target flag
-- Checking whether C compiler supports OSX deployment target flag - yes
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Checking whether CXX compiler has -isysroot
-- Checking whether CXX compiler has -isysroot - yes
-- Checking whether CXX compiler supports OSX deployment target flag
-- Checking whether CXX compiler supports OSX deployment target flag - yes
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = '-pipe -O2 -arch x86_64 -frounding-math
-fno-strict-aliasing -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -L/opt/local/lib -arch x86_64
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=10
-- Mac Leopard detected
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
EIGEN3_INCLUDE_DIR
-- Build files have been written to:
/Users/drorata/Documents/academics/programing/CGAL/Surface_reconstruction_points_3_CGAL_4
---(Output END)---
Then trying to compile the example yielded:
---(Output)---
In file included from
/opt/local/include/CGAL/Poisson_reconstruction_function.h:32,
from
/Users/drorata/Documents/academics/programing/CGAL/Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:10:
/opt/local/include/CGAL/Eigen_solver_traits.h:24:24: error: Eigen/Sparse: No
such file or directory
In file included from /opt/local/include/CGAL/Eigen_solver_traits.h:26,
from
from
/opt/local/include/CGAL/Eigen_vector.h:24:22: error: Eigen/Core: No such file
or directory
...(CONTINUES)
---(Output END)---
This seems not to work.
I don't think that the problem is finding EIGEN. Currently I have (as Michael
Hemmer suggested) the following line in my CMakeLists.txt:
include_directories (BEFORE "~/Library/eigen3.1.0-rc1/")
It seems like neither your suggestion nor setting EIGEN3_INC_DIR to the
eigen's location helps.
Anyway, with either Michael's trick or Menelaos' (which was adding a soft
link to the include directory of the example which pointed to the location of
eigen) it seems like eigen can be found, but the compilation error is always
there.
Dror.
On Jun 20, 2012, at 16:55 PM, Sebastien Loriot (GeometryFactory) wrote:
> Try:
> There should be no need to do something else for the demo.
> This was documented on that page:
> http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4
> Sebastien.
> On 06/20/2012 04:19 PM,
> wrote:
>> I have installed *CGAL 4.0* on a Mac OS 10.6 using *macports*. As a test
>> case, I tried to compile the example given in /Triangulation_2/, using the
>> standard procedure:
>> - cgal_create_cmake_script
>> - cmake .
>> - make
>> This worked like a charm and suggests, if I understand it correctly, that
>> CGAL's installation is OK.
>> Next, I wanted to compile and consider the example
>> /Surface_reconstruction_points_3/. Here things got messy. I'll try to
>> describe the steps I took (some of them with the great help of Menelaos
>> Karavelas and Michael Hemmer. Thank you Menelaos and MIchael) in order to
>> resolve the issue.
>> The version of Eigen shipped with the CGAL installation through macports is
>> old, and thus I downloaded manually the latest version of eigen
>> (3.1.0-rc1).
>> In addition, I added the following line to the CMakeLists.txt:
>> where ~/Library/eigen3.1.0-rc1/ is where the file
>> "signature_of_eigen3_matrix_library" is located.
>> This should make sure that eigen will be looked for in the right location.
>> Then I added
>> #define CGAL_EIGEN3_ENABLED
>> to the example "poisson_reconstruction_example.cpp". Finally, I ran:
>> - cmake .
>> - make poisson_reconstruction_example
>> Then I got the following compilation error:
>> ---Compilation Error Cite---
>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h: In copy
>> constructor
>> ‘Eigen::IterativeSolverBase<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> >
>>> ::IterativeSolverBase(const
>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’:
>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/IterativeLinearSolvers/
>> IterativeSolverBase.h:37: instantiated from ‘bool
>> CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function()
>> [with
>> Gt = CGAL::Epick]’
>> Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:65:
>> instantiated from here
>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h:113:
>> error:
>> ‘Eigen::internal::noncopyable::noncopyable(const
>> Eigen::internal::noncopyable&)’ is private
>> IterativeSolverBase.h:37: error: within this context
>> ConjugateGradient.h: In copy constructor
>> ‘Eigen::ConjugateGradient<Eigen::SparseMatrix<double, 0, int>, 1,
>> Eigen::DiagonalPreconditioner<double> >::ConjugateGradient(const
>> Eigen::DiagonalPreconditioner<double> >&)’:
>> ConjugateGradient.h:160: instantiated from ‘bool
>> [with
>> Gt = CGAL::Epick]’
>> ConjugateGradient.h:160: note: synthesized method
>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’ first required
>> here
>> /opt/local/include/CGAL/Eigen_solver_traits.h: In copy constructor
>> ‘CGAL::Eigen_solver_traits<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
>>> ::Eigen_solver_traits(const
>> /opt/local/include/CGAL/Eigen_solver_traits.h:58: instantiated from ‘bool
>> [with
>> Gt = CGAL::Epick]’
>> /opt/local/include/CGAL/Eigen_solver_traits.h:58: note: synthesized method
>> Eigen::DiagonalPreconditioner<double> >&)’ first required here
>> /opt/local/include/CGAL/Poisson_reconstruction_function.h: In member
>> function
>> ‘bool
>> [with Gt = CGAL::Epick]’:
>> /opt/local/include/CGAL/Poisson_reconstruction_function.h:264: note:
>> synthesized method
>> here
>> make[3]: *** [CMakeFiles/poisson_reconstruction_example.dir/
>> poisson_reconstruction_example.cpp.o] Error 1
>> make[2]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2
>> make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/rule] Error 2
>> make: *** [poisson_reconstruction_example] Error 2
>> ---Compilation Error END---
>> I am unable to find what the problem is? Seems like it is either a problem
>> in
>> EIGEN, or the way it is being using in CGAL/this specific example.
>> If further details regarding my setting etc. is needed please let me know.
>> Thanks in advance!
>> Dror Atariah
>> PS: I'm in Chapel Hill till tomorrow, so if you're around I'm available to
>> have a look at the problem together.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Dror Atariah
Freie Universität Berlin
Landline: +49-30-83875159
Mobile: +49-176-20280996
http://page.mi.fu-berlin.de/atariah/
