cgal-discuss - Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • To:
  • Subject: Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • Date: Tue, 26 Jun 2012 09:50:44 +0200
>> Well, I compiled the example using the alpha version of eigen and obtained
>> an executable (i.e. no compilation errors were generated). Then I tried to
>> run it and go the "Segmentation fault".
>> Let me know what further details can I provide?
> You mean the application crashes at start up or when you try to run a
> reconstruction?
> Could you give information about you system (MacOS version, compiler,
> version of QT,...)
I only managed to compile "poisson_reconstruction_example.cpp". When I
execute the generated executable it immediately returns a "Segmentation
fault".
I use MacOS 10.6.8. The compiler is probably the default one - I don't know
which one I'm actually using (direction on how to find it will help). As for
the QT - I have no idea.
