cgal-discuss - Re: [cgal-discuss] CGAL newbie question
  • To:
  • Subject: Re: [cgal-discuss] CGAL newbie question
  • Date: Mon, 10 Sep 2012 10:26:59 +0200
Le 9/9/12 8:18 AM, Manu Kaul a écrit :
Hi all,
I used the "Triangle" library from http://www.cs.cmu.edu/~quake/triangle.html <http://www.cs.cmu.edu/%7Equake/triangle.html> by Jonathan Shewchuck to generate a Delaunay triangulation
of my raw x,y,z points. I am trying to create an indexing structure and some distance bounds that make the shortest path calculation on a
terrain faster + some other queries like range queries, and k-nearest neighbour queries as well.
I noticed that in order to do some of these things I might need CGAL, but I understand that the learning curve can be quite steep.
The things I need to do are :
1. Generate TINs at multiple levels of details by introducing Steiner points.
2. Being able to access the triangles and its adjacent triangles in raw form (like 0 1 2 vertices of triangle in counter-clockwise format)
so that I can feed it to a "Chen and Han" shortest path implementation by O'Rourke (http://cs.smith.edu/~orourke/ShortestPaths/ <http://cs.smith.edu/%7Eorourke/ShortestPaths/>)
3. Have the ability to compute the slope of each triangle and also all its interior angles.
4. Need to be able to *project* onto the terrain the 3D euclidean line between any two points of the terrain.
5. Generate a Voronoi diagram from the Delaunay (Triangle generates this too)
2 Triangulation of a terrain is what you need:
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_37.5.2
4 The triangles intersected by the vertical projection of a line on the terrain are given by
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Nested_type_Line_face_circulator
5 use "dual" fonctions of vertices and faces
3 are just basic computations
1 you have to manage levels of details yourself. CGAL triangulation supports insertion and deletions.
