- To:
- Subject: Re: [cgal-discuss] CGAL newbie question
- Date: Mon, 10 Sep 2012 10:45:47 +0200
Le 10/09/12 10:29, Manu Kaul a écrit :
Thanks Monique and Olivier. Will look into the tutorials. Its just that
I haven't done much generic programming either, so wondering what the
learning curve will be in that case.
There is a learning curve, but I don't think that the "generic programming" aspect itself is adding major difficulties (and it is a good opportunity to learn more about it).
The difficulty is proportional to the needs. If you do easy things that are already on the shelf, then it is easy. The examples should help a lot.
If you need precisely tailored complex stuff, things are getting harder. That's fair...
Have fun.
On Mon, Sep 10, 2012 at 10:26 AM, Olivier Devillers
<mailto:>>
wrote:
Le 9/9/12 8:18 AM, Manu Kaul a écrit :
Hi all,
I used the "Triangle" library from
http://www.cs.cmu.edu/~quake/__triangle.html
<http://www.cs.cmu.edu/%7Equake/triangle.html>
<http://www.cs.cmu.edu/%__7Equake/triangle.html
<http://www.cs.cmu.edu/%7Equake/triangle.html>> by Jonathan
Shewchuck to generate a Delaunay triangulation
of my raw x,y,z points. I am trying to create an indexing
structure and some distance bounds that make the shortest path
calculation on a
terrain faster + some other queries like range queries, and
k-nearest neighbour queries as well.
I noticed that in order to do some of these things I might need
CGAL, but I understand that the learning curve can be quite steep.
The things I need to do are :
1. Generate TINs at multiple levels of details by introducing
Steiner points.
2. Being able to access the triangles and its adjacent triangles
in raw form (like 0 1 2 vertices of triangle in
counter-clockwise format)
so that I can feed it to a "Chen and Han" shortest path
implementation by O'Rourke
(http://cs.smith.edu/~orourke/__ShortestPaths/
<http://cs.smith.edu/%7Eorourke/ShortestPaths/>
<http://cs.smith.edu/%__7Eorourke/ShortestPaths/
<http://cs.smith.edu/%7Eorourke/ShortestPaths/>>)
3. Have the ability to compute the slope of each triangle and
also all its interior angles.
4. Need to be able to *project* onto the terrain the 3D
euclidean line between any two points of the terrain.
5. Generate a Voronoi diagram from the Delaunay (Triangle
generates this too)
2 Triangulation of a terrain is what you need:
http://www.cgal.org/Manual/__beta/doc_html/cgal_manual/__Triangulation_2/Chapter_main.__html#Subsection_37.5.2
<http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_37.5.2>
4 The triangles intersected by the vertical projection of a line on
the terrain are given by
http://www.cgal.org/Manual/__beta/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.html#Nested___type_Line_face_circulator
<http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Nested_type_Line_face_circulator>
5 use "dual" fonctions of vertices and faces
3 are just basic computations
1 you have to manage levels of details yourself. CGAL triangulation
supports insertion and deletions.
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
The greater danger for most of us lies not in setting our aim too high
and falling short; but in setting our aim too low, and achieving our mark.
- Michelangelo
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] CGAL newbie question, Manu Kaul, 09/09/2012
- Re: [cgal-discuss] CGAL newbie question, Monique Teillaud, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Olivier Devillers, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Manu Kaul, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Philipp Moeller, 09/10/2012
