- To:
- Subject: Re: [cgal-discuss] CGAL newbie question
- Date: Mon, 10 Sep 2012 10:29:47 +0200
Thanks Monique and Olivier. Will look into the tutorials. Its just that I haven't done much generic programming either, so wondering what the
learning curve will be in that case.
On Mon, Sep 10, 2012 at 10:26 AM, Olivier Devillers <> wrote:
Le 9/9/12 8:18 AM, Manu Kaul a écrit :
Hi all,2 Triangulation of a terrain is what you need:
I used the "Triangle" library from http://www.cs.cmu.edu/~quake/triangle.html <http://www.cs.cmu.edu/%7Equake/triangle.html> by Jonathan Shewchuck to generate a Delaunay triangulationso that I can feed it to a "Chen and Han" shortest path implementation by O'Rourke (http://cs.smith.edu/~orourke/ShortestPaths/ <http://cs.smith.edu/%7Eorourke/ShortestPaths/>)
of my raw x,y,z points. I am trying to create an indexing structure and some distance bounds that make the shortest path calculation on a
terrain faster + some other queries like range queries, and k-nearest neighbour queries as well.
I noticed that in order to do some of these things I might need CGAL, but I understand that the learning curve can be quite steep.
The things I need to do are :
1. Generate TINs at multiple levels of details by introducing Steiner points.
2. Being able to access the triangles and its adjacent triangles in raw form (like 0 1 2 vertices of triangle in counter-clockwise format)
3. Have the ability to compute the slope of each triangle and also all its interior angles.
4. Need to be able to *project* onto the terrain the 3D euclidean line between any two points of the terrain.
5. Generate a Voronoi diagram from the Delaunay (Triangle generates this too)
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_37.5.2
4 The triangles intersected by the vertical projection of a line on the terrain are given by
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Nested_type_Line_face_circulator
5 use "dual" fonctions of vertices and faces
3 are just basic computations
1 you have to manage levels of details yourself. CGAL triangulation supports insertion and deletions.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
- Michelangelo
- [cgal-discuss] CGAL newbie question, Manu Kaul, 09/09/2012
- Re: [cgal-discuss] CGAL newbie question, Monique Teillaud, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Olivier Devillers, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Manu Kaul, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Philipp Moeller, 09/10/2012
