- To:
- Subject: Re: [cgal-discuss] CGAL newbie question
- Date: Mon, 10 Sep 2012 10:26:53 +0200
Le 09/09/12 08:18, Manu Kaul a écrit :
Hi all,
I used the "Triangle" library from
http://www.cs.cmu.edu/~quake/triangle.html by Jonathan Shewchuck to
generate a Delaunay triangulation
of my raw x,y,z points. I am trying to create an indexing structure and
some distance bounds that make the shortest path calculation on a
terrain faster + some other queries like range queries, and k-nearest
neighbour queries as well.
I noticed that in order to do some of these things I might need CGAL,
but I understand that the learning curve can be quite steep.
The things I need to do are :
1. Generate TINs at multiple levels of details by introducing Steiner
points.
2. Being able to access the triangles and its adjacent triangles in raw
form (like 0 1 2 vertices of triangle in counter-clockwise format)
so that I can feed it to a "Chen and Han" shortest path implementation
by O'Rourke (http://cs.smith.edu/~orourke/ShortestPaths/)
3. Have the ability to compute the slope of each triangle and also all
its interior angles.
4. Need to be able to *project* onto the terrain the 3D euclidean line
between any two points of the terrain.
5. Generate a Voronoi diagram from the Delaunay (Triangle generates this
too)
Hi,
An email will certainly not be able to summarize everything you can do with CGAL triangulations... the CGAL manual does it much better.
The user manual presents an overview, together with examples http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html
Then the reference manual gives all details.
In a nutshell, the 2D triangulation package allows to compute Delaunay triangulations and gives dual functions to get Voronoi features.
It has many functionalities.
There is a specific traits class Projection_traits_xy_3 for the case of a terrain.
There are functions computing angles in the CGAL Kernel.
There is a Voronoi diagram package.
There is also an interface to the BGL that should help for shortest paths http://www.cgal.org/Manual/latest/doc_html/cgal_manual/BGL/Chapter_main.html
Someone who used CGAL mentioned that traversing over faces of a
triangulation in CGAL can be quite cumbersome
strange... the package provides several iterators and circulators to easily traverse triangulations in various ways.
Best,
Monique Teillaud
and that I should
instead convert it to a polyhedron and use the iterator there. So I just
want to understand if CGAL will be able to help me with all the
things I need to do and if I might get stuck halfway? Hopefully CGAL
will not be overkill for what I am trying to do? I found another C++
library that used the DECL (http://www.holmes3d.net/graphics/dcel/),
would this be easier to use than CGAL for what I am trying to achieve?
I ask since I am not going to do very complicated computational geometry
related work on the surface, if CGAL would be too much to work with?
Thanks,
Manu
The greater danger for most of us lies not in setting our aim too high
and falling short; but in setting our aim too low, and achieving our mark.
- Michelangelo
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] CGAL newbie question, Manu Kaul, 09/09/2012
- Re: [cgal-discuss] CGAL newbie question, Monique Teillaud, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Olivier Devillers, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Manu Kaul, 09/10/2012
- Re: [cgal-discuss] CGAL newbie question, Philipp Moeller, 09/10/2012
