- To: <>
- Subject: Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
- Date: Wed, 24 Oct 2012 08:18:43 -0500
I'll take a look at that.
Last night I wrote a fairly basic block of code that followed the halfedge_iterator from halfedge_begin() to halfedge_end(), calling join_vertex() any time the squared distance between two was smaller than numeric_limits<float>::epsilon().
It did a fine job of pruning degenerate edges, but never converged (spit out a list of a dozen or so pruned edges, but ran all night at 100% cpu with no change in memory usage).
So my assumption is that by calling join_vertex on a running loop I'm breaking something, or these iterators never converge somehow. Am I doing this wrong?
-rd
On 10/24/2012 02:16 AM, Sebastien Loriot (GeometryFactory) wrote:
You can try using the edge simplification algorithm [1]
There is an example given in this thread (second post) [2]
Let us know if this does not solve the problem.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html
[2] http://cgal-discuss.949826.n4.nabble.com/understanding-edge-collapse-tt3248855.html
On 10/24/2012 01:51 AM, Richard Downe wrote:
I have a program that uses Nef_Polyhedron_3 to merge several disjoint
structured grids, and then remeshes the surface using a delaunay
triangulation. Out of several surfaces I'm preparing, one has stubbornly
refused to mesh. After a day or so of tweaking the parameters, I
generated .off files to permit me to visualize the intermediate surface
and troubleshoot.
In examining the .off version of the troublesome surface, I noticed that
there are several degenerate triangles (e.g., 2 coincident vertices, and
therefore a zero-valued normal). I'm assuming this has to do with
distances in the EPECK kernel that are too small to represent in the
EPICK kernel, which therefore get rounded off.
My question is this: does a filter exist which can remove these
triangles *prior* to casting the polyhedron to an EPICK kernel? Or am I
on my own (e.g., either filtering the inexact kernel version and simply
erasing the degenerate triangles, or alternately, filtering the exact
one and merging any triangle with a sufficiently high aspect ratio with
an adjacent triangle in the hopes of avoiding degeneracy post-cast)?
Any help would be very much appreciated.
-Richard
- [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/25/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/25/2012
