cgal-discuss - Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
  • To: <>
  • Subject: Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
  • Date: Thu, 25 Oct 2012 12:35:34 -0500
The export to polyhedron induces a dummy triangulation of the facets.
This means that the very long edges comes from the fact that in the
original mesh you have long quad facets.
This I have a hard time believing. My input surfaces are all pure triangle surfaces, where each rectangle from the structured grid is bisected into 2 right triangles. They're evenly spaced, and only suboptimal at the end-caps, where I just triangulate around a single center point.
Looking closely at the flow extensions, which are where the skinny long triangles emerge, I see occasional remnants of my original surface in triangles scattered about in odd places. The flow extensions, which is the only place this ever crops up, are functionally "straight-pipe" models, so that they could properly be represented by a very small number of long skinny triangles, as they have no curvature in the longitudinal direction, or are "flat" in the topological sense of a cylinder. I'm convinced that the NEF code pares down the number of triangles based on this "flatness".
One solution to simplify the boolean operation step is to first remesh
your input and then do the union. That way I'm quite sure you are going
to remove the degenerate triangle problem.
If my hypothesis regarding the reason why the long skinny triangles appear is correct, I'm not certain this will solve the problem. Though I suppose the fact that the points will no longer be arranged along a grid of parallel lines may dissuade the NEF code from rearranging them so. Nonetheless, I'm running low on options; I will give it a try and report back.
Thanks.
-rd
Sebastien.
On 10/25/2012 01:31 AM, Richard Downe wrote:
Couldn't get it to work right manipulating the iterators directly, but I
took your original advice, used the triangulated surface mesh
simplification stuff (I used the edge_length cost, and set the stopping
condition to 0.99*nEdges).
This completely eliminates the degenerate triangles I had with
coincident points (I'm able to feed the .off intermediate output into my
program for building STL files without errors/zero-valued normals being
detected).
Unfortunately, this surface is still stubbornly refusing remeshing. I've
attached a dropbox link to the .off output (post-surface simplification,
pre-remeshing) on the off chance that something about it might catch
your eye.
(The really long edges at the flow extensions are not my doing -- these
invariably appear *post* Nef_polyhedron.)
Thanks.
-rd
http://dl.dropbox.com/u/66958528/cgal.off
On 10/24/2012 08:22 AM, Sebastien Loriot (GeometryFactory) wrote:
On 10/24/2012 03:18 PM, Richard Downe wrote:
I'll take a look at that.
Last night I wrote a fairly basic block of code that followed the
halfedge_iterator from halfedge_begin() to halfedge_end(), calling
join_vertex() any time the squared distance between two was smaller than
numeric_limits<float>::epsilon().
It did a fine job of pruning degenerate edges, but never converged (spit
out a list of a dozen or so pruned edges, but ran all night at 100% cpu
with no change in memory usage).
So my assumption is that by calling join_vertex on a running loop I'm
breaking something, or these iterators never converge somehow. Am I
doing this wrong?
I guess the iterator became invalid. Joining two vertices means
deleting a pair of halfedges.
If you ++ the iterator before joining it should be fine as the
underlying data structure is a list by default.
Note that you might need to do this loop several time as you could
have cascaded collapse with such a method.
Sebastien.
-rd
On 10/24/2012 02:16 AM, Sebastien Loriot (GeometryFactory) wrote:
You can try using the edge simplification algorithm [1]
There is an example given in this thread (second post) [2]
Let us know if this does not solve the problem.
Sebastien.
[1]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html
[2]
http://cgal-discuss.949826.n4.nabble.com/understanding-edge-collapse-tt3248855.html
On 10/24/2012 01:51 AM, Richard Downe wrote:
I have a program that uses Nef_Polyhedron_3 to merge several disjoint
structured grids, and then remeshes the surface using a delaunay
triangulation. Out of several surfaces I'm preparing, one has
stubbornly
refused to mesh. After a day or so of tweaking the parameters, I
generated .off files to permit me to visualize the intermediate
surface
and troubleshoot.
In examining the .off version of the troublesome surface, I noticed
that
there are several degenerate triangles (e.g., 2 coincident
vertices, and
therefore a zero-valued normal). I'm assuming this has to do with
distances in the EPECK kernel that are too small to represent in the
EPICK kernel, which therefore get rounded off.
My question is this: does a filter exist which can remove these
triangles *prior* to casting the polyhedron to an EPICK kernel? Or
am I
on my own (e.g., either filtering the inexact kernel version and
simply
erasing the degenerate triangles, or alternately, filtering the exact
one and merging any triangle with a sufficiently high aspect ratio
with
an adjacent triangle in the hopes of avoiding degeneracy post-cast)?
Any help would be very much appreciated.
-Richard
