- To: <>
- Subject: Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
- Date: Wed, 24 Oct 2012 18:31:04 -0500
Couldn't get it to work right
manipulating the iterators directly, but I took your original
advice, used the triangulated surface mesh simplification stuff (I
used the edge_length cost, and set the stopping condition to
0.99*nEdges).
This completely eliminates the degenerate triangles I had with coincident points (I'm able to feed the .off intermediate output into my program for building STL files without errors/zero-valued normals being detected). Unfortunately, this surface is still stubbornly refusing remeshing. I've attached a dropbox link to the .off output (post-surface simplification, pre-remeshing) on the off chance that something about it might catch your eye. (The really long edges at the flow extensions are not my doing -- these invariably appear *post* Nef_polyhedron.) Thanks. -rd http://dl.dropbox.com/u/66958528/cgal.off On 10/24/2012 08:22 AM, Sebastien Loriot (GeometryFactory) wrote: On 10/24/2012 03:18 PM, Richard Downe wrote: |
- [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/25/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/25/2012
