- To:
- Subject: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
- Date: Wed, 23 Jan 2013 10:17:35 +0100
As already said, compile the CGAL library also in debug mode.
Sebastien.
On 01/23/2013 09:40 AM, sara wrote:
Hi all , can you help me about not founding 'CGAL-vc100-mt-gd-4.0.lib' in my
computer .
I have installed CGAL correctly in 64 bit windows and test it with CMake
2.8.9 and when I try to debug the CGAL.sln that cmake build it I see this
error 'CGAL-vc100-mt-gd-4.0.lib' .
when I am tring to debug every example file that is build with cmake I will
se this error again.
Thanks a lot
Sara
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-vc100-mt-gd-4-0-lib-tp4656535.html
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
