- To: "" <>
- Subject: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
- Date: Wed, 23 Jan 2013 01:26:16 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=bdQj5rVfD6Ys2g08pmbjVJK0CCE1hD8LPd80BxF2CSM1F1UixwFqPtiqvEr8jdFDFg76+f0tAzdRb5ZOZbwttDRtvyX6DJF1oiCgP99txPDWjhLZGKXij/YH1pnrTRbwylYoHZ0ztsZE5Uuvsif72K3Nqm/KNLZIDQFBH2fqmIo=;
Hi , Sebastien Loriot
Thanks for replying . It can not be compile in debug or release mode . when I try every one it finishes with the same error . sorry me but is it possible to explain more .
Thanks alot.
To:
Sent: Wednesday, January 23, 2013 1:17 AM
As already said, compile the CGAL library also in debug mode.
Sebastien.
On 01/23/2013 09:40 AM, sara wrote:
> Hi all , can you help me about not founding 'CGAL-vc100-mt-gd-4.0.lib' in my
> computer .
> I have installed CGAL correctly in 64 bit windows and test it with CMake
> 2.8.9 and when I try to debug the CGAL.sln that cmake build it I see this
> error 'CGAL-vc100-mt-gd-4.0.lib' .
> when I am tring to debug every example file that is build with cmake I will
> se this error again.
> Thanks a lot
> Sara
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/CGAL-vc100-mt-gd-4-0-lib-tp4656535.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
