- To:
- Subject: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
- Date: Wed, 23 Jan 2013 12:39:13 +0100
What are you trying to compile? An example or the CGAL library?
If this is an example, then you need to compile the CGAL library in debug mode.
Sebastien.
On 01/23/2013 12:27 PM, sara ershadi wrote:
Hi ,
This is the error :
2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
*To:*
*Sent:* Wednesday, January 23, 2013 1:38 PM
*Subject:* Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
Le mercredi 23 janvier 2013 01:26:16 sara ershadi a écrit :
> Hi , Sebastien Loriot
> Thanks for replying . It can not be compile in debug or release mode
. when
> I try every one it finishes with the same error . sorry me but is it
> possible to explain more . Thanks alot.
You should show us the error you are talking about.
Laurent Rineau, PhD
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
