- To:
- Subject: Re: [cgal-discuss] Re: Sequence of boolops on general polygons
- Date: Mon, 11 Feb 2013 16:58:08 +0200
Thank you for the patch. I have applied it.
The changes will be included in the next release.
On Tue, Feb 5, 2013 at 9:06 PM, Shriramana Sharma <> wrote:
On Tue, Feb 5, 2013 at 4:36 PM, Shriramana Sharma <> wrote:I have since come across bezier_traits_adapter2.cpp within the
> Should I simply use this line with the above Traits_2 and I will get a
> type I can use for multiple successive operations as described above?
examples dir (but not mentioned in the documentation) which clearly
uses
typedef CGAL::Gps_traits_2<Traits_2> Bezier_traits;
typedef CGAL::General_polygon_set_2<Bezier_traits> Bezier_polygon_set;
so I guess that's what I'll use too. BTW I have a small patch for this
example which I attach. Would be nice if it could be incorporated for
a future release.
Shriramana Sharma
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
- [cgal-discuss] Sequence of boolops on general polygons, Shriramana Sharma, 02/05/2013
- [cgal-discuss] Re: Sequence of boolops on general polygons, Shriramana Sharma, 02/05/2013
- Re: [cgal-discuss] Re: Sequence of boolops on general polygons, Efi Fogel, 02/11/2013
- Re: [cgal-discuss] Re: Sequence of boolops on general polygons, Ophir Setter, 02/05/2013
- Re: [cgal-discuss] Re: Sequence of boolops on general polygons, Shriramana Sharma, 02/12/2013
