cgal-discuss - Re: [cgal-discuss] Re: Sequence of boolops on general polygons
  • To:
  • Subject: Re: [cgal-discuss] Re: Sequence of boolops on general polygons
  • Date: Mon, 11 Feb 2013 17:09:48 +0200
On Tue, Feb 5, 2013 at 1:40 PM, Shriramana Sharma <> wrote:
In this connection I also have some queries regarding the lines which
are found in the example bezier_traits_adapter.cpp:
typedef CGAL::Gps_traits_2<Traits_2>                    Gps_traits_2;
typedef Gps_traits_2::General_polygon_2                 Polygon_2;
typedef Gps_traits_2::General_polygon_with_holes_2      Polygon_with_holes_2;
typedef std::list<Polygon_with_holes_2>                 Polygon_set;
1)
a) Whether CGAL::General_polygon_set_2<Traits_2> cannot be used in the
place of the last line?
No---these are two different entities. (Perhaps you know this by now...)
b) Or perhaps should CGAL::General_polygon_set_2<Gps_traits_2> be used?
Nop
c) What is the difference between Gps_traits_2 and Traits_2?
The former is a model of the concept GeneralPolygonSetTraits_2.
The latter is a model of the concept ArrangementDirectionalXMonotoneTraits_2.
The concept GeneralPolygonSetTraits_2 is a generalization of the concept ArrangementDirectionalXMonotoneTraits_2.
2) In the previous example the lines:
typedef CGAL::General_polygon_set_2<Traits_2>             Polygon_set_2;
typedef Traits_2::General_polygon_2                       Polygon_2;
typedef Traits_2::General_polygon_with_holes_2            Polygon_with_holes_2;
... are seen so why in this example the typedefs of Polygon and
Polygon_with_holes are done from Gps_traits_2 and not Traits_2
directly? (This connects with 1b and 1c above.)
Traits_2 does not provide these nested types. These types are exactly the additional requirements of the generalization.
3) Why isn't there a consistent interface:
typedef CGAL::General_polygon_2<Traits_2>             Polygon_2;
typedef CGAL::General_polygon_with_holes_2<Traits_2>
but Polygon_set_2 is always initialized from the template with the
traits class as parameter and the other two are instead typedef-ed
from a member type of the traits class?
I don't know exactly how to answer this question except for saying that these types serve different purposes, so naturally they different interfaces are used.
Shriramana Sharma
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
