- To:
- Subject: [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?
- Date: Tue, 12 Mar 2013 10:44:42 -0700 (PDT)
Dear all,
I am trying to work on Boolean operations by CGAL and there are some
problems. After the operations, the output OFF file shows that there are
facets which intersect each other. Could anyone help me to take a look at
it?
You can reproduce the problem in Windows 7 64bit + VS2010 (Visual C++) +
boost_1_52 with the attached code. I don't know whether the problem can be
reproduced in other environment or not.
If you find there are some problems in my code, please also point out it for
me and help me to correct it.
Thanks,
Zhanghong Tang
booleantest.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4656931/booleantest.cpp>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/bugs-of-Boolean-operations-in-CGAL-4-2-beta-and-4-1-tp4656931.html
- [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/12/2013
- Re: [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/14/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/14/2013
- Re: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/15/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/15/2013
