cgal-discuss - [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?
  • To:
  • Subject: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?
  • Date: Thu, 14 Mar 2013 08:36:39 -0700 (PDT)
Dear Dr. Loriot,
Thank you very much for your kindly reply. My original case is much more
complex than this example. I have already reduced the code to let it be able
to reproduce the problem. If I replace more code with the data, the problem
can't be reproduced.
In my problem, there are 5 steps:
1) create a cylinder (cyl0.off);
2) create a slot (slot.off);
3) substract a slot from the cylinder (cyl1.off);
4) create a oblique slot (slot2.off);
5) union the substracted cylinder with the oblique slot (cyl2.off).
I have attached the updated code and generated OFF files. Could you please
help me to take a look at it and point out the problem in the code (I don't
know whether the problem is lead by my code or not).
Thanks,
Zhanghong Tang
booleantest.zip
<http://cgal-discuss.949826.n4.nabble.com/file/n4656958/booleantest.zip>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/bugs-of-Boolean-operations-in-CGAL-4-2-beta-and-4-1-tp4656931p4656958.html
