- To:
- Subject: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?
- Date: Fri, 15 Mar 2013 05:37:35 -0700 (PDT)
Dear Dr. Loriot,
Thank you very much for your kindly reply.
In my previous reply, I just do as you said to modify that file and redo
everything (rebuild the project to generate new libraries, rebuild my
program which link to the libraries and rerun my program to generate OFF
files), however, the results are still the same. So I guess that the
modification to that file has no effect to the results, and then I tried to
delete that file and found that everything can run as before.
I guess that is not correct so I ask for your help to tell me what I have
missed:)
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/bugs-of-Boolean-operations-in-CGAL-4-2-beta-and-4-1-tp4656931p4656974.html
- [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/12/2013
- Re: [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/14/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/14/2013
- Re: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/15/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/15/2013
