- To:
- Subject: Re: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?
- Date: Fri, 15 Mar 2013 08:21:41 +0100
I seems there is an issue in CGAL/IO/generic_print_polyhedron.h
Can you temporarily modify this file and remove the ::CGAL::to_double
Sebastien.
On 03/15/2013 08:11 AM, tang wrote:
Dear Dr. Loriot,
I have modified the code to take CGAL::Simple_cartesian<CGAL::Gmpq> as
kernel to generate OFF files, but the results are exactly the same as what I
did before. Could you please give me a small example on how to use this
kernel to generate OFF files?
On the other hand, I have reduced the code to let the boolean operations
focus on the OFF files directly. There are some warnings outputted in
windows and the result OFF is still not correct. Could you please help me to
take a look at it?
Thanks,
Zhanghong Tang
booleantest.zip
<http://cgal-discuss.949826.n4.nabble.com/file/n4656965/booleantest.zip>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/bugs-of-Boolean-operations-in-CGAL-4-2-beta-and-4-1-tp4656931p4656965.html
- [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/12/2013
- Re: [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/14/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/14/2013
- Re: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/15/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/15/2013
