- To:
- Subject: Re: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?
- Date: Fri, 15 Mar 2013 13:12:01 +0100
I said:
"Can you temporarily modify this file and remove the ::CGAL::to_double "
which means editing the file not deleting it :)
Just modify it the time to generate the files and then restore it.
Sebastien.
On 03/15/2013 01:07 PM, tang wrote:
Dear Dr. Loriot,
Further investigation shows that when I delete the file
'CGAL/IO/generic_print_polyhedron.h' and rebuild the CGAL library, both the
projects and my program can still be built successfully (I only used the
projects CGAL, CGAL_ImageIO and CGAL_Qt4).
Is there anything I missed?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/bugs-of-Boolean-operations-in-CGAL-4-2-beta-and-4-1-tp4656931p4656972.html
- [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/12/2013
- Re: [cgal-discuss] bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/14/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/14/2013
- Re: [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, Sebastien Loriot (GeometryFactory), 03/15/2013
- [cgal-discuss] Re: bugs of Boolean operations in CGAL 4.2 beta and 4.1?, tang, 03/15/2013
