- To:
- Subject: [cgal-discuss] Re: Extracting triangulation from alpha shape
- Date: Fri, 2 Aug 2013 04:55:56 -0700 (PDT)
Hi Sebastien,
Many thanks for your indications. I struggled a bit to find the correct way to combine Triangulation_vertex_base_with_info_3 and Alpha_shape_3, but it seems to work in the end. Here's a code snippet in case it's useful for somebody else (I'm programming a Matlab MEX C++ function, so some types are specific to Matlab)
<CODE>
/* CGAL headers */
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
#include <CGAL/Alpha_shape_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
// vertex
typedef CGAL::Triangulation_vertex_base_with_info_3<mwSize, K> Vb;
typedef CGAL::Alpha_shape_vertex_base_3<K, Vb> AsVb;
// cell
typedef CGAL::Alpha_shape_cell_base_3<K> Fb;
// triangulation structure: vertex and cell
typedef CGAL::Triangulation_data_structure_3<AsVb, Fb> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
typedef CGAL::Alpha_shape_3<Delaunay> Alpha_shape_3;
typedef K::Point_3 Point;
typedef std::pair<Point, mwIndex> PointWithIndex;
typedef Alpha_shape_3::Alpha_iterator Alpha_iterator;
typedef Alpha_shape_3::Facet Facet;
// read points from function
std::vector<PointWithIndex> x(nrowsX);
for (mwIndex i = 0; i < nrowsX; ++i) {
x[i] = std::make_pair(
some_function_to_read_a_point(i),
i+1 // because this will be a row index in Matlab, 1, ..., Nrows
// Delaunay triangulation
Delaunay delaunay(x.begin(), x.end());
CGAL_assertion(delaunay.number_of_vertices() == nrowsX);
// compute alpha shape
Alpha_shape_3 as(delaunay);
</CODE>
Best regards,
Ramón.
On 2 August 2013 06:29, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
Use one of the following examples [1] to build the triangulation of your
points and set their indices. Then build the alpha shape from the
triangulation.
then you can do:
typedef CGAL::Delaunay_triangulation_3<.....> DT3;
for (std::list<Facet>::iterator it = facets.begin(); it != facets.end();
++it)
it->first->vertex( DT3::vertex_triple_index(it->second,0) )->info();
it->first->vertex( DT3::vertex_triple_index(it->second,1) )->info();
it->first->vertex( DT3::vertex_triple_index(it->second,2) )->info();
Sebastien.
[1]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_39.5.3
On 08/01/2013 08:44 PM, rcasero wrote:>
> Dear all,
> I'm computing alpha shapes on a set of points
> std::vector<Point> x =
> some_function_to_read_points();
> Alpha_shape_3 as(x.begin(), x.end());
> based on the example from the "3D Alpha shapes" documentation:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html#Subsection_43.5.1>
> What I would like to do now is extract the triangulation of a given alpha
> shape in index form, e.g.
> tri = [3 2 8
> 2 1 3
> where the indices are the indices of the points in the x vector above.
> This is similar to a previous question I got help from Sebastien Loriot to
> http://cgal-discuss.949826.n4.nabble.com/Getting-index-of-facet-closest-to-a-point-tp4657635.html>
> but I don't manage to find the right pointers in this case so that I can do
> something like
> std::distance(x.begin(), some_iterator_here);
> to get the index.
> I can get a list of the facets
> // get alpha-shape surface
> std::list<Facet> facets;
> as.get_alpha_shape_facets(std::back_inserter(facets),
> Alpha_shape_3::REGULAR);
> and I can iterate said facets
> ++it) {
> From the documentation and an old question replied to by sloriot
> http://stackoverflow.com/questions/7938311/cgal-help-getting-triangles-coordinates-from-delaunay-triangulation> Sent from the cgal-discuss mailing list archive at Nabble.com.
> I know I can the coordinates of the facet vertices as
> ++it) {
> it->first->vertex((it->second+1)%4)->point();
> it->first->vertex((it->second+2)%4)->point();
> it->first->vertex((it->second+3)%4)->point();
> but the it->...->point(); above are not pointing to elements in x, neither
> it->first->vertex((it->second+1)%4).
> Many thanks for any help or, ahem, pointers.
> Best regards,
> Ramon.
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870.html
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657872.html
Dr. Ramón Casero Cañas
Oxford e-Research Centre (OeRC)
University of Oxford
7 Keble Rd
Oxford OX1 3QG
tlf +44 (0) 1865 610739
web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas
photos http://www.flickr.com/photos/rcasero/
View this message in context: Re: Extracting triangulation from alpha shape
- [cgal-discuss] Extracting triangulation from alpha shape, rcasero, 08/01/2013
- Re: [cgal-discuss] Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/05/2013
- Re: [cgal-discuss] Re: Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/05/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/06/2013
