cgal-discuss - Re: [cgal-discuss] Re: Extracting triangulation from alpha shape
  • To:
  • Subject: Re: [cgal-discuss] Re: Extracting triangulation from alpha shape
  • Date: Mon, 05 Aug 2013 16:48:09 +0200
On 08/05/2013 04:33 PM, rcasero wrote:
Many thanks for your quick reply and fix. I have updated the alpha shape
function here
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalAlphaShape3.cpp?r=1285
and added your patched file here
https://code.google.com/p/gerardus/source/browse/trunk/cpp/src/third-party/CGAL-4.2/include/CGAL/Triangulation_hierarchy_3.h?spec=svn1285&r=1285
<https://code.google.com/p/gerardus/source/browse/trunk/cpp/src/third-party/CGAL-4.2/include/CGAL/Triangulation_hierarchy_3.h?spec=svn1285&r=1285>
(As a side note, I haven't noticed a speed improvement with the 400,000
point example).
for the location or the insertion?
Sebastien.
Best regards,
Ramon.
On 5 August 2013 14:08, Sebastien Loriot (GeometryFactory) [via
cgal-discuss] <[hidden email]
</user/SendEmail.jtp?type=node&node=4657883&i=0>> wrote:
It's a bug.
Try with the attached file instead of the one in CGAL/.
Sebastien.
On 08/05/2013 02:20 PM, rcasero wrote:
> Hi,
> As a follow up, I have commited the Matlab MEX function that uses
CGAL's
> Alpha_Shape_3 here [1] to share
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalAlphaShape3.cpp?r=1284
> That code builds and works. But as I have point sets with 400,000+
> points, I tried to add the flag CGAL::Fast_location to the Delaunay
> triangulation, replacing
> typedefCGAL::Delaunay_triangulation_3<K,Tds>Delaunay;
> with
> typedef CGAL::Delaunay_triangulation_3<K, Tds, CGAL::Fast_location>
> Delaunay;
> as in example"43.5.2 Building Basic Alpha Shapes for Many Points"
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html#Subsection_43.5.2
> However, this seems to give trouble with the PointWithIndex
class, and I
> get a compilation error. The full error is given below, but
digging a
> bit into it, it seems that the problem is with
/home/rcasero/Documents/gerardus/matlab/CgalToolbox/CgalAlphaShape3.cpp:175:
> instantiated from here
> /usr/include/c++/4.4/bits/stl_uninitialized.h:74: error: no matching
> function for call to
‘CGAL::Point_3<CGAL::Epick>::Point_3(std::pair<CGAL::Point_3<CGAL::Epick>,
> long unsigned int>&)’
> Line 175 of CgalAlphaShape3.cpp is
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalAlphaShape3.cpp?r=1284#175
> <CODE>
> Delaunay delaunay(x.begin(), x.end());
> </CODE>
> So is this a limitation of the Delaunay triangulation class when
using a
> PointWithIndex, that only happens with CGAL::Fast_location? Or am I
> reading the error the wrong way?
> Best regards,
> Ramon.
> <FULL ERROR>
> [100%] Building CXX object
matlab/CgalToolbox/CMakeFiles/cgal_alpha_shape3.dir/CgalAlphaShape3.cpp.o
> In file included from /usr/include/c++/4.4/vector:64,
> from
> /usr/local/include/ITK-4.3/itkMetaDataDictionary.h:22,
> from /usr/local/include/ITK-4.3/itkObject.h:33,
> from
/usr/local/include/ITK-4.3/itkDataObject.h:31,
> from
/usr/local/include/ITK-4.3/itkProcessObject.h:31,
> from
/usr/local/include/ITK-4.3/itkImageSource.h:31,
> from
/usr/local/include/ITK-4.3/itkImportImageFilter.h:21,
> from
/home/rcasero/Documents/gerardus/matlab/CgalToolbox/../MatlabImportFilter.h:52,
> from
/home/rcasero/Documents/gerardus/matlab/CgalToolbox/CgalAlphaShape3.cpp:81:
> /usr/include/c++/4.4/bits/stl_uninitialized.h: In static member
function
> ‘static _ForwardIterator std::__uninitialized_copy<<anonymous>
> >::uninitialized_copy(_InputIterator, _InputIterator,
_ForwardIterator)
> [with _InputIterator =
__gnu_cxx::__normal_iterator<std::pair<CGAL::Point_3<CGAL::Epick>, long
> unsigned int>*, std::vector<std::pair<CGAL::Point_3<CGAL::Epick>,
long
> unsigned int>,
std::allocator<std::pair<CGAL::Point_3<CGAL::Epick>, long
> unsigned int> > > >, _ForwardIterator = CGAL::Point_3<CGAL::Epick>*,
> bool <anonymous> = false]’:
> /usr/include/c++/4.4/bits/stl_uninitialized.h:117: instantiated
from
> ‘_ForwardIterator std::uninitialized_copy(_InputIterator,
> _InputIterator, _ForwardIterator) [with _InputIterator =
long
> unsigned int>,
CGAL::Point_3<CGAL::Epick>*]’
> /usr/include/c++/4.4/bits/stl_uninitialized.h:257: instantiated
from
> ‘_ForwardIterator std::__uninitialized_copy_a(_InputIterator,
> _InputIterator, _ForwardIterator, std::allocator<_Tp>&) [with
> _InputIterator =
long
> unsigned int>,
CGAL::Point_3<CGAL::Epick>*, _Tp
> = CGAL::Point_3<CGAL::Epick>]’
> /usr/include/c++/4.4/bits/stl_vector.h:1024: instantiated from
‘void
> std::vector<_Tp, _Alloc>::_M_range_initialize(_ForwardIterator,
> _ForwardIterator, std::forward_iterator_tag) [with
_ForwardIterator =
long
> unsigned int>,
> unsigned int> > > >, _Tp = CGAL::Point_3<CGAL::Epick>, _Alloc =
> std::allocator<CGAL::Point_3<CGAL::Epick> >]’
> /usr/include/c++/4.4/bits/stl_vector.h:1002: instantiated from
‘void
> std::vector<_Tp, _Alloc>::_M_initialize_dispatch(_InputIterator,
> _InputIterator, std::__false_type) [with _InputIterator =
long
> unsigned int>,
> /usr/include/c++/4.4/bits/stl_vector.h:303: instantiated from
> ‘std::vector<_Tp, _Alloc>::vector(_InputIterator, _InputIterator,
const
> _Alloc&) [with _InputIterator =
long
> unsigned int>,
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Triangulation_hierarchy_3.h:133:
> instantiated from ‘ptrdiff_t
> CGAL::Triangulation_hierarchy_3<Tr>::insert(InputIterator,
> InputIterator) [with InputIterator =
long
> unsigned int>,
> unsigned int> > > >, Tr =
CGAL::Delaunay_triangulation_3<CGAL::Epick,
CGAL::Triangulation_data_structure_3<CGAL::Triangulation_hierarchy_vertex_base_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Epick,
> CGAL::Triangulation_vertex_base_with_info_3<long unsigned int,
> CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Epick,
> CGAL::Triangulation_ds_vertex_base_3<void> > >,
> CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> >,
> CGAL::Alpha_shape_cell_base_3<CGAL::Epick, CGAL::Default,
> CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > > > > >,
> CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > >,
CGAL::Default>]’
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Triangulation_hierarchy_3.h:98:
> instantiated from
‘CGAL::Triangulation_hierarchy_3<Tr>::Triangulation_hierarchy_3(InputIterator,
> InputIterator, const typename Tr::Geom_traits&) [with
InputIterator =
long
> unsigned int>,
CGAL::Default>]’
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/internal/Delaunay_triangulation_hierarchy_3.h:55:
> instantiated from ‘CGAL::Delaunay_triangulation_3<Gt, Tds_,
> CGAL::Location_policy<CGAL::Fast>
> >::Delaunay_triangulation_3(InputIterator, InputIterator, const Gt&)
long
> unsigned int>,
> unsigned int> > > >, Gt = CGAL::Epick, Tds_ =
> CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > >]’
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:83:
> note: candidates are: CGAL::Point_3<R_>::Point_3(const typename
R_::RT&,
> const typename R_::RT&, const typename R_::RT&, const typename
R_::RT&)
> [with R_ = CGAL::Epick]
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:75:
> note: CGAL::Point_3<R_>::Point_3(const typename
> R_::Kernel_base::Point_3&) [with R_ = CGAL::Epick]
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:71:
CGAL::Origin&)
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:69:
> note: CGAL::Point_3<R_>::Point_3() [with R_ =
CGAL::Epick]
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:40:
> note: CGAL::Point_3<CGAL::Epick>::Point_3(const
> CGAL::Point_3<CGAL::Epick>&)
> make[2]: ***
[matlab/CgalToolbox/CMakeFiles/cgal_alpha_shape3.dir/CgalAlphaShape3.cpp.o]
> Error 1
> make[1]: ***
[matlab/CgalToolbox/CMakeFiles/cgal_alpha_shape3.dir/all]
> Error 2
> make: *** [all] Error 2
> </FULL ERROR>
> On 2 August 2013 12:55, Ramón Casero Cañas <[hidden email]
> </user/SendEmail.jtp?type=node&node=4657880&i=0>> wrote:
> Hi Sebastien,
> Many thanks for your indications. I struggled a bit to find the
> correct way to combine Triangulation_vertex_base_with_info_3
> and Alpha_shape_3, but it seems to work in the end. Here's a
code
> snippet in case it's useful for somebody else (I'm programming a
> Matlab MEX C++ function, so some types are specific to Matlab)
> <CODE>
> /* CGAL headers */
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/Delaunay_triangulation_3.h>
> #include <CGAL/Triangulation_vertex_base_with_info_3.h>
> #include <CGAL/Alpha_shape_3.h>
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> // vertex
> typedef CGAL::Triangulation_vertex_base_with_info_3<mwSize,
K> Vb;
> typedef CGAL::Alpha_shape_vertex_base_3<K, Vb> AsVb;
> // cell
> typedef CGAL::Alpha_shape_cell_base_3<K> Fb;
> // triangulation structure: vertex and cell
> typedef CGAL::Triangulation_data_structure_3<AsVb, Fb> Tds;
> typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
> typedef CGAL::Alpha_shape_3<Delaunay>
Alpha_shape_3;
> typedef K::Point_3 Point;
> typedef std::pair<Point, mwIndex>
PointWithIndex;
> typedef Alpha_shape_3::Alpha_iterator
Alpha_iterator;
> typedef Alpha_shape_3::Facet Facet;
> // read points from function
> std::vector<PointWithIndex> x(nrowsX);
> for (mwIndex i = 0; i < nrowsX; ++i) {
> x[i] = std::make_pair(
> some_function_to_read_a_point(i),
> i+1 // because this will be a row index in Matlab, 1, ...,
Nrows
> // Delaunay triangulation
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_39.5.3
> CGAL_assertion(delaunay.number_of_vertices() == nrowsX);
> // compute alpha shape
> Alpha_shape_3 as(delaunay);
> </CODE>
> Best regards,
> Ramón.
> On 2 August 2013 06:29, Sebastien Loriot (GeometryFactory) [via
> </user/SendEmail.jtp?type=node&node=4657880&i=1>> wrote:
> Use one of the following examples [1] to build the
triangulation
> of your
> points and set their indices. Then build the alpha shape
from the
> triangulation.
> then you can do:
> typedef CGAL::Delaunay_triangulation_3<.....> DT3;
> for (std::list<Facet>::iterator it = facets.begin(); it !=
> facets.end();
> ++it)
> it->first->vertex(
DT3::vertex_triple_index(it->second,0)
> )->info();
> it->first->vertex(
DT3::vertex_triple_index(it->second,1)
> )->info();
> it->first->vertex(
DT3::vertex_triple_index(it->second,2)
> )->info();
> Sebastien.
> [1]
> On 08/01/2013 08:44 PM, rcasero wrote:
> > Dear all,
> > I'm computing alpha shapes on a set of points
> > std::vector<Point> x =
> > some_function_to_read_points();
> > Alpha_shape_3 as(x.begin(), x.end());
> > based on the example from the "3D Alpha shapes" documentation:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html#Subsection_43.5.1
> > What I would like to do now is extract the triangulation of a
> given alpha
> > shape in index form, e.g.
> > tri = [3 2 8
> > 2 1 3
> > where the indices are the indices of the points in the x
> vector above.
> > This is similar to a previous question I got help from
> Sebastien Loriot to
http://cgal-discuss.949826.n4.nabble.com/Getting-index-of-facet-closest-to-a-point-tp4657635.html
> > but I don't manage to find the right pointers in this case so
> that I can do
> > something like
> > std::distance(x.begin(), some_iterator_here);
> > to get the index.
> > I can get a list of the facets
> > // get alpha-shape surface
> > std::list<Facet> facets;
> > as.get_alpha_shape_facets(std::back_inserter(facets),
> > Alpha_shape_3::REGULAR);
> > and I can iterate said facets
> facets.end();
> > ++it) {
> > From the documentation and an old question replied to by
> sloriot
http://stackoverflow.com/questions/7938311/cgal-help-getting-triangles-coordinates-from-delaunay-triangulation
> > I know I can the coordinates of the facet vertices as
> facets.end();
> > ++it) {
> > it->first->vertex((it->second+1)%4)->point();
> > it->first->vertex((it->second+2)%4)->point();
> > it->first->vertex((it->second+3)%4)->point();
> > but the it->...->point(); above are not pointing to elements
> in x, neither
> > it->first->vertex((it->second+1)%4).
> > Many thanks for any help or, ahem, pointers.
> > Best regards,
> > Ramon.
> > View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870.html
> > Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> If you reply to this email, your message will be added to
the
> discussion below:
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657872.html
> To unsubscribe from Extracting triangulation from alpha
shape,
> click here.
> NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>>
> Dr. Ramón Casero Cañas
> Oxford e-Research Centre (OeRC)
> University of Oxford
> 7 Keble Rd
> Oxford OX1 3QG
> tlf <a href="tel:%2B44%20%280%29%201865%20610739"
> value="<a href="tel:%2B441865610739" value="+441865610739"
target="_blank">+441865610739" target="_blank"><a
href="tel:%2B44%20%280%29%201865%20610739" value="+441865610739"
target="_blank">+44 (0) 1865 610739
> web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas
> photos http://www.flickr.com/photos/rcasero/
> 7 Keble Rd
> Oxford OX1 3QG
value="+441865610739" target="_blank">+44 (0) 1865 610739
> View this message in context: Re: Extracting triangulation from
alpha
> shape
<http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657880.html>
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
*Triangulation_hierarchy_3.h* (35K) Download Attachment
<http://cgal-discuss.949826.n4.nabble.com/attachment/4657881/0/Triangulation_hierarchy_3.h>
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657881.html
To unsubscribe from Extracting triangulation from alpha shape, click
here.
NAML
7 Keble Rd
Oxford OX1 3QG
tlf +44 (0) 1865 610739
View this message in context: Re: Extracting triangulation from alpha
shape
<http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657883.html>
