- To:
- Subject: Re: [cgal-discuss] Re: Extracting triangulation from alpha shape
- Date: Mon, 05 Aug 2013 15:06:30 +0200
It's a bug.
Try with the attached file instead of the one in CGAL/.
Sebastien.
On 08/05/2013 02:20 PM, rcasero wrote:
Hi,
As a follow up, I have commited the Matlab MEX function that uses CGAL's
Alpha_Shape_3 here [1] to share
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalAlphaShape3.cpp?r=1284
That code builds and works. But as I have point sets with 400,000+
points, I tried to add the flag CGAL::Fast_location to the Delaunay
triangulation, replacing
typedefCGAL::Delaunay_triangulation_3<K,Tds>Delaunay;
with
typedef CGAL::Delaunay_triangulation_3<K, Tds, CGAL::Fast_location>
Delaunay;
as in example"43.5.2 Building Basic Alpha Shapes for Many Points"
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html#Subsection_43.5.2
However, this seems to give trouble with the PointWithIndex class, and I
get a compilation error. The full error is given below, but digging a
bit into it, it seems that the problem is with
/home/rcasero/Documents/gerardus/matlab/CgalToolbox/CgalAlphaShape3.cpp:175:
instantiated from here
/usr/include/c++/4.4/bits/stl_uninitialized.h:74: error: no matching
function for call to
‘CGAL::Point_3<CGAL::Epick>::Point_3(std::pair<CGAL::Point_3<CGAL::Epick>,
long unsigned int>&)’
Line 175 of CgalAlphaShape3.cpp is
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalAlphaShape3.cpp?r=1284#175
<CODE>
Delaunay delaunay(x.begin(), x.end());
</CODE>
So is this a limitation of the Delaunay triangulation class when using a
PointWithIndex, that only happens with CGAL::Fast_location? Or am I
reading the error the wrong way?
Best regards,
Ramon.
<FULL ERROR>
[100%] Building CXX object
matlab/CgalToolbox/CMakeFiles/cgal_alpha_shape3.dir/CgalAlphaShape3.cpp.o
In file included from /usr/include/c++/4.4/vector:64,
from
/usr/local/include/ITK-4.3/itkMetaDataDictionary.h:22,
from /usr/local/include/ITK-4.3/itkObject.h:33,
from /usr/local/include/ITK-4.3/itkDataObject.h:31,
from /usr/local/include/ITK-4.3/itkProcessObject.h:31,
from /usr/local/include/ITK-4.3/itkImageSource.h:31,
from /usr/local/include/ITK-4.3/itkImportImageFilter.h:21,
from
/home/rcasero/Documents/gerardus/matlab/CgalToolbox/../MatlabImportFilter.h:52,
from
/home/rcasero/Documents/gerardus/matlab/CgalToolbox/CgalAlphaShape3.cpp:81:
/usr/include/c++/4.4/bits/stl_uninitialized.h: In static member function
‘static _ForwardIterator std::__uninitialized_copy<<anonymous>
>::uninitialized_copy(_InputIterator, _InputIterator, _ForwardIterator)
[with _InputIterator =
__gnu_cxx::__normal_iterator<std::pair<CGAL::Point_3<CGAL::Epick>, long
unsigned int>*, std::vector<std::pair<CGAL::Point_3<CGAL::Epick>, long
unsigned int>, std::allocator<std::pair<CGAL::Point_3<CGAL::Epick>, long
unsigned int> > > >, _ForwardIterator = CGAL::Point_3<CGAL::Epick>*,
bool <anonymous> = false]’:
/usr/include/c++/4.4/bits/stl_uninitialized.h:117: instantiated from
‘_ForwardIterator std::uninitialized_copy(_InputIterator,
_InputIterator, _ForwardIterator) [with _InputIterator =
unsigned int> > > >, _ForwardIterator = CGAL::Point_3<CGAL::Epick>*]’
/usr/include/c++/4.4/bits/stl_uninitialized.h:257: instantiated from
‘_ForwardIterator std::__uninitialized_copy_a(_InputIterator,
_InputIterator, _ForwardIterator, std::allocator<_Tp>&) [with
_InputIterator =
unsigned int> > > >, _ForwardIterator = CGAL::Point_3<CGAL::Epick>*, _Tp
= CGAL::Point_3<CGAL::Epick>]’
/usr/include/c++/4.4/bits/stl_vector.h:1024: instantiated from ‘void
std::vector<_Tp, _Alloc>::_M_range_initialize(_ForwardIterator,
_ForwardIterator, std::forward_iterator_tag) [with _ForwardIterator =
unsigned int> > > >, _Tp = CGAL::Point_3<CGAL::Epick>, _Alloc =
std::allocator<CGAL::Point_3<CGAL::Epick> >]’
/usr/include/c++/4.4/bits/stl_vector.h:1002: instantiated from ‘void
std::vector<_Tp, _Alloc>::_M_initialize_dispatch(_InputIterator,
_InputIterator, std::__false_type) [with _InputIterator =
/usr/include/c++/4.4/bits/stl_vector.h:303: instantiated from
‘std::vector<_Tp, _Alloc>::vector(_InputIterator, _InputIterator, const
_Alloc&) [with _InputIterator =
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Triangulation_hierarchy_3.h:133:
instantiated from ‘ptrdiff_t
CGAL::Triangulation_hierarchy_3<Tr>::insert(InputIterator,
InputIterator) [with InputIterator =
unsigned int> > > >, Tr = CGAL::Delaunay_triangulation_3<CGAL::Epick,
CGAL::Triangulation_data_structure_3<CGAL::Triangulation_hierarchy_vertex_base_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Epick,
CGAL::Triangulation_vertex_base_with_info_3<long unsigned int,
CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Epick,
CGAL::Triangulation_ds_vertex_base_3<void> > >,
CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> >,
CGAL::Alpha_shape_cell_base_3<CGAL::Epick, CGAL::Default,
CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > > > > >,
CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > >,
CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > >, CGAL::Default>]’
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Triangulation_hierarchy_3.h:98:
instantiated from
‘CGAL::Triangulation_hierarchy_3<Tr>::Triangulation_hierarchy_3(InputIterator,
InputIterator, const typename Tr::Geom_traits&) [with InputIterator =
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/internal/Delaunay_triangulation_hierarchy_3.h:55:
instantiated from ‘CGAL::Delaunay_triangulation_3<Gt, Tds_,
CGAL::Location_policy<CGAL::Fast>
>::Delaunay_triangulation_3(InputIterator, InputIterator, const Gt&)
unsigned int> > > >, Gt = CGAL::Epick, Tds_ =
CGAL::Boolean_tag<false>, CGAL::Boolean_tag<false> > >]’
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:83:
note: candidates are: CGAL::Point_3<R_>::Point_3(const typename R_::RT&,
const typename R_::RT&, const typename R_::RT&, const typename R_::RT&)
[with R_ = CGAL::Epick]
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:75:
note: CGAL::Point_3<R_>::Point_3(const typename
R_::Kernel_base::Point_3&) [with R_ = CGAL::Epick]
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:71:
note: CGAL::Point_3<R_>::Point_3(const CGAL::Origin&)
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:69:
note: CGAL::Point_3<R_>::Point_3() [with R_ = CGAL::Epick]
/home/rcasero/Documents/gerardus/cpp/src/third-party/CGAL-4.2/include/CGAL/Point_3.h:40:
note: CGAL::Point_3<CGAL::Epick>::Point_3(const
CGAL::Point_3<CGAL::Epick>&)
make[2]: ***
[matlab/CgalToolbox/CMakeFiles/cgal_alpha_shape3.dir/CgalAlphaShape3.cpp.o]
Error 1
make[1]: *** [matlab/CgalToolbox/CMakeFiles/cgal_alpha_shape3.dir/all]
Error 2
make: *** [all] Error 2
</FULL ERROR>
On 2 August 2013 12:55, Ramón Casero Cañas <[hidden email]
</user/SendEmail.jtp?type=node&node=4657880&i=0>> wrote:
Hi Sebastien,
Many thanks for your indications. I struggled a bit to find the
correct way to combine Triangulation_vertex_base_with_info_3
and Alpha_shape_3, but it seems to work in the end. Here's a code
snippet in case it's useful for somebody else (I'm programming a
Matlab MEX C++ function, so some types are specific to Matlab)
<CODE>
/* CGAL headers */
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
#include <CGAL/Alpha_shape_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
// vertex
typedef CGAL::Triangulation_vertex_base_with_info_3<mwSize, K> Vb;
typedef CGAL::Alpha_shape_vertex_base_3<K, Vb> AsVb;
// cell
typedef CGAL::Alpha_shape_cell_base_3<K> Fb;
// triangulation structure: vertex and cell
typedef CGAL::Triangulation_data_structure_3<AsVb, Fb> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
typedef CGAL::Alpha_shape_3<Delaunay> Alpha_shape_3;
typedef K::Point_3 Point;
typedef std::pair<Point, mwIndex> PointWithIndex;
typedef Alpha_shape_3::Alpha_iterator Alpha_iterator;
typedef Alpha_shape_3::Facet Facet;
// read points from function
std::vector<PointWithIndex> x(nrowsX);
for (mwIndex i = 0; i < nrowsX; ++i) {
x[i] = std::make_pair(
some_function_to_read_a_point(i),
i+1 // because this will be a row index in Matlab, 1, ..., Nrows
// Delaunay triangulation
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_39.5.3
CGAL_assertion(delaunay.number_of_vertices() == nrowsX);
// compute alpha shape
Alpha_shape_3 as(delaunay);
</CODE>
Best regards,
Ramón.
On 2 August 2013 06:29, Sebastien Loriot (GeometryFactory) [via
cgal-discuss] <[hidden email]
</user/SendEmail.jtp?type=node&node=4657880&i=1>> wrote:
Use one of the following examples [1] to build the triangulation
of your
points and set their indices. Then build the alpha shape from the
triangulation.
then you can do:
typedef CGAL::Delaunay_triangulation_3<.....> DT3;
for (std::list<Facet>::iterator it = facets.begin(); it !=
facets.end();
++it)
it->first->vertex( DT3::vertex_triple_index(it->second,0)
)->info();
it->first->vertex( DT3::vertex_triple_index(it->second,1)
)->info();
it->first->vertex( DT3::vertex_triple_index(it->second,2)
)->info();
Sebastien.
[1]
On 08/01/2013 08:44 PM, rcasero wrote:
> Dear all,
> I'm computing alpha shapes on a set of points
> std::vector<Point> x =
> some_function_to_read_points();
> Alpha_shape_3 as(x.begin(), x.end());
> based on the example from the "3D Alpha shapes" documentation:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html#Subsection_43.5.1
> What I would like to do now is extract the triangulation of a
given alpha
> shape in index form, e.g.
> tri = [3 2 8
> 2 1 3
> where the indices are the indices of the points in the x
vector above.
> This is similar to a previous question I got help from
Sebastien Loriot to
http://cgal-discuss.949826.n4.nabble.com/Getting-index-of-facet-closest-to-a-point-tp4657635.html
> but I don't manage to find the right pointers in this case so
that I can do
> something like
> std::distance(x.begin(), some_iterator_here);
> to get the index.
> I can get a list of the facets
> // get alpha-shape surface
> std::list<Facet> facets;
> as.get_alpha_shape_facets(std::back_inserter(facets),
> Alpha_shape_3::REGULAR);
> and I can iterate said facets
facets.end();
> ++it) {
> From the documentation and an old question replied to by
sloriot
http://stackoverflow.com/questions/7938311/cgal-help-getting-triangles-coordinates-from-delaunay-triangulation
> I know I can the coordinates of the facet vertices as
facets.end();
> ++it) {
> it->first->vertex((it->second+1)%4)->point();
> it->first->vertex((it->second+2)%4)->point();
> it->first->vertex((it->second+3)%4)->point();
> but the it->...->point(); above are not pointing to elements
in x, neither
> it->first->vertex((it->second+1)%4).
> Many thanks for any help or, ahem, pointers.
> Best regards,
> Ramon.
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657872.html
To unsubscribe from Extracting triangulation from alpha shape,
click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Dr. Ramón Casero Cañas
Oxford e-Research Centre (OeRC)
University of Oxford
7 Keble Rd
Oxford OX1 3QG
tlf <a href="tel:%2B44%20%280%29%201865%20610739"
value="+441865610739" target="_blank">+44 (0) 1865 610739
web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas
photos http://www.flickr.com/photos/rcasero/
7 Keble Rd
Oxford OX1 3QG
tlf +44 (0) 1865 610739
View this message in context: Re: Extracting triangulation from alpha
shape
<http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657880.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
// Copyright (c) 1998, 2001, 2003 INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org).
// You can redistribute it and/or modify it under the terms of the GNU
// General Public License as published by the Free Software Foundation,
// either version 3 of the License, or (at your option) any later version.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL$
// $Id$
// Author(s) : Olivier Devillers
// Sylvain Pion
#ifndef CGAL_TRIANGULATION_HIERARCHY_3_H
#define CGAL_TRIANGULATION_HIERARCHY_3_H
#include <CGAL/basic.h>
#include <CGAL/triangulation_assertions.h>
#include <CGAL/Triangulation_hierarchy_vertex_base_3.h>
#include <CGAL/Location_policy.h>
#include <boost/random/linear_congruential.hpp>
#include <boost/random/geometric_distribution.hpp>
#include <boost/random/variate_generator.hpp>
#ifndef CGAL_TRIANGULATION_3_DONT_INSERT_RANGE_OF_POINTS_WITH_INFO
#include <CGAL/Spatial_sort_traits_adapter_3.h>
#include <CGAL/internal/info_check.h>
#include <boost/tuple/tuple.hpp>
#include <boost/iterator/zip_iterator.hpp>
#include <boost/mpl/and.hpp>
#endif //CGAL_TRIANGULATION_3_DONT_INSERT_RANGE_OF_POINTS_WITH_INFO
namespace CGAL {
// This class is deprecated, but must be kept for backward compatibility.
// It would be better to move its content to the Delaunay_triangulation_3
// specializations for Fast_location and make Triangulation_hierarchy_3 the
// empty nutshell instead.
// Then, later, maybe merge the Compact/Fast codes in a cleaner factorized
way.
template < class Tr >
class Triangulation_hierarchy_3
: public Tr
// parameterization of the hierarchy
// maximal number of points is 30^5 = 24 millions !
enum { ratio = 30 };
enum { minsize = 20};
enum { maxlevel = 5};
public:
typedef Tr Tr_Base;
typedef Fast_location Location_policy;
typedef typename Tr_Base::Geom_traits Geom_traits;
typedef typename Tr_Base::Point Point;
typedef typename Tr_Base::size_type size_type;
typedef typename Tr_Base::Vertex_handle Vertex_handle;
typedef typename Tr_Base::Cell_handle Cell_handle;
typedef typename Tr_Base::Vertex_iterator Vertex_iterator;
typedef typename Tr_Base::Vertex Vertex;
typedef typename Tr_Base::Locate_type Locate_type;
typedef typename Tr_Base::Finite_vertices_iterator
Finite_vertices_iterator;
typedef typename Tr_Base::Finite_cells_iterator Finite_cells_iterator;
typedef typename Tr_Base::Finite_facets_iterator Finite_facets_iterator;
typedef typename Tr_Base::Finite_edges_iterator Finite_edges_iterator;
using Tr_Base::number_of_vertices;
using Tr_Base::geom_traits;
private:
// here is the stack of triangulations which form the hierarchy
Tr_Base* hierarchy[maxlevel];
boost::rand48 random;
void set_up_down(Vertex_handle up, Vertex_handle down)
up->set_down(down);
down->set_up(up);
public:
Triangulation_hierarchy_3(const Geom_traits& traits = Geom_traits());
Triangulation_hierarchy_3(const Triangulation_hierarchy_3& tr);
template < typename InputIterator >
Triangulation_hierarchy_3(InputIterator first, InputIterator last,
: Tr_Base(traits)
hierarchy[0] = this;
for(int i=1; i<maxlevel; ++i)
hierarchy[i] = new Tr_Base(traits);
insert(first, last);
Triangulation_hierarchy_3 & operator=(const Triangulation_hierarchy_3& tr)
Triangulation_hierarchy_3 tmp(tr);
swap(tmp);
return *this;
~Triangulation_hierarchy_3();
void swap(Triangulation_hierarchy_3 &tr);
void clear();
// CHECKING
bool is_valid(bool verbose = false, int level = 0) const;
// INSERT REMOVE
Vertex_handle insert(const Point &p, Vertex_handle hint)
return insert(p, hint == Vertex_handle() ? this->infinite_cell() :
hint->cell());
Vertex_handle insert(const Point &p, Cell_handle start = Cell_handle ());
Vertex_handle insert(const Point &p, Locate_type lt, Cell_handle loc,
int li, int lj);
template < class InputIterator >
std::ptrdiff_t
insert( InputIterator first, InputIterator last,
typename boost::enable_if<
boost::is_convertible<
typename std::iterator_traits<InputIterator>::value_type,
Point
>::type* = NULL
#else
std::ptrdiff_t
insert( InputIterator first, InputIterator last)
size_type n = number_of_vertices();
std::vector<Point> points (first, last);
spatial_sort (points.begin(), points.end(), geom_traits());
// hints[i] is the vertex of the previously inserted point in level i.
// Thanks to spatial sort, they are better hints than what the hierarchy
// would give us.
Vertex_handle hints[maxlevel];
for (typename std::vector<Point>::const_iterator p = points.begin(),
end = points.end();
p != end; ++p)
int vertex_level = random_level();
Vertex_handle v = hints[0] = hierarchy[0]->insert (*p, hints[0]);
Vertex_handle prev = v;
for (int level = 1; level <= vertex_level; ++level) {
v = hints[level] = hierarchy[level]->insert (*p, hints[level]);
set_up_down(v, prev);
prev = v;
return number_of_vertices() - n;
private:
//top stands for tuple-or-pair
template <class Info>
const Point& top_get_first(const std::pair<Point,Info>& pair) const {
return pair.first; }
const Info& top_get_second(const std::pair<Point,Info>& pair) const {
return pair.second; }
const Point& top_get_first(const boost::tuple<Point,Info>& tuple) const {
return boost::get<0>(tuple); }
const Info& top_get_second(const boost::tuple<Point,Info>& tuple) const {
return boost::get<1>(tuple); }
template <class Tuple_or_pair,class InputIterator>
std::ptrdiff_t insert_with_info(InputIterator first,InputIterator last)
std::vector<std::ptrdiff_t> indices;
std::vector<Point> points;
std::vector<typename Vertex::Info> infos;
std::ptrdiff_t index=0;
for (InputIterator it=first;it!=last;++it){
Tuple_or_pair value=*it;
points.push_back( top_get_first(value) );
infos.push_back ( top_get_second(value) );
indices.push_back(index++);
typedef Spatial_sort_traits_adapter_3<Geom_traits,Point*> Search_traits;
spatial_sort(indices.begin(),indices.end(),Search_traits(&(points[0]),geom_traits()));
// would give us.
for (typename std::vector<std::ptrdiff_t>::const_iterator
it = indices.begin(), end = indices.end();
it != end; ++it)
Vertex_handle v = hints[0] = hierarchy[0]->insert (points[*it],
hints[0]);
v->info()=infos[*it];
v = hints[level] = hierarchy[level]->insert (points[*it],
hints[level]);
prev = v;
public:
std::ptrdiff_t
InputIterator last,
std::pair<Point,typename internal::Info_check<Vertex>::type>
> >::type* =NULL
return insert_with_info< std::pair<Point,typename
internal::Info_check<Vertex>::type> >(first,last);
template <class InputIterator_1,class InputIterator_2>
std::ptrdiff_t
insert( boost::zip_iterator< boost::tuple<InputIterator_1,InputIterator_2>
> first,
> last,
boost::mpl::and_<
boost::is_convertible< typename
std::iterator_traits<InputIterator_1>::value_type, Point >,
std::iterator_traits<InputIterator_2>::value_type, typename
internal::Info_check<Vertex>::type >
>::type* =NULL
return insert_with_info< boost::tuple<Point,typename
void remove(Vertex_handle v);
size_type remove(InputIterator first, InputIterator beyond)
while (first != beyond) {
remove(*first);
++first;
return n - number_of_vertices();
size_type remove_cluster(InputIterator first, InputIterator beyond)
CGAL_triangulation_precondition(!this->does_repeat_in_range(first,
beyond));
CGAL_triangulation_precondition(!this->infinite_vertex_in_range(first,
beyond));
size_type n = this->number_of_vertices();
std::vector<Vertex_handle> vo(first, beyond), vc;
int l=0;
while(1) {
size_type n = vo.size();
if(n == 0) break;
for(size_type i=0; i<n; i++) {
if(vo[i]->up() != Vertex_handle()) vc.push_back(vo[i]->up());
hierarchy[l++]->remove_cluster(vo.begin(), vo.end());
std::swap(vo,vc);
vc.clear();
return n - this->number_of_vertices();
#ifndef CGAL_NO_DEPRECATED_CODE
CGAL_DEPRECATED Vertex_handle move_point(Vertex_handle v, const Point & p);
#endif
Vertex_handle move_if_no_collision(Vertex_handle v, const Point &p);
Vertex_handle move(Vertex_handle v, const Point &p);
public: // some internal methods
// INSERT REMOVE DISPLACEMENT
// GIVING NEW FACES
template <class OutputItCells>
Vertex_handle insert_and_give_new_cells(const Point &p,
OutputItCells fit,
Cell_handle start = Cell_handle() );
Vertex_handle insert_and_give_new_cells(const Point& p,
OutputItCells /* fit */,
Vertex_handle hint)
return insert_and_give_new_cells(p, hint == Vertex_handle() ?
this->infinite_cell() : hint->cell());
Locate_type lt,
Cell_handle c, int li, int lj,
OutputItCells fit);
void remove_and_give_new_cells(Vertex_handle v,
OutputItCells fit);
Vertex_handle move_if_no_collision_and_give_new_cells(Vertex_handle v,
const Point &p,
OutputItCells fit);
public:
//LOCATE
Cell_handle locate(const Point& p, Locate_type& lt, int& li, int& lj,
Vertex_handle hint) const
return locate(p, lt, li, lj, hint == Vertex_handle() ?
Cell_handle locate(const Point& p, Vertex_handle hint) const
return locate(p, hint == Vertex_handle() ? this->infinite_cell() :
hint->cell());
Cell_handle start = Cell_handle ()) const;
Cell_handle locate(const Point& p, Cell_handle start = Cell_handle ())
const;
Vertex_handle
nearest_vertex(const Point& p, Cell_handle start = Cell_handle()) const;
protected:
struct locs {
Cell_handle pos;
int li, lj;
Locate_type lt;
void locate(const Point& p, Locate_type& lt, int& li, int& lj,
locs pos[maxlevel], Cell_handle start = Cell_handle ()) const;
int random_level();
template <class Tr >
Triangulation_hierarchy_3(const Geom_traits& traits)
: Tr_Base(traits)
for(int i=1;i<maxlevel;++i)
// copy constructor duplicates vertices and cells
template <class Tr>
Triangulation_hierarchy_3(const Triangulation_hierarchy_3<Tr> &tr)
: Tr_Base(tr)
hierarchy[i] = new Tr_Base(*tr.hierarchy[i]);
// up and down have been copied in straightforward way
// compute a map at lower level
std::map< Vertex_handle, Vertex_handle > V;
for( Finite_vertices_iterator it = hierarchy[0]->finite_vertices_begin(),
end = hierarchy[0]->finite_vertices_end(); it != end; ++it)
if (it->up() != Vertex_handle())
V[ it->up()->down() ] = it;
for(int j=1; j<maxlevel; ++j) {
for( Finite_vertices_iterator it = hierarchy[j]->finite_vertices_begin(),
end = hierarchy[j]->finite_vertices_end(); it != end; ++it) {
// current it->down() pointer goes in original instead in copied
triangulation
set_up_down(it, V[it->down()]);
// make map for next level
template <class Tr>
void
swap(Triangulation_hierarchy_3<Tr> &tr)
Tr_Base::swap(tr);
std::swap(hierarchy[i], tr.hierarchy[i]);
template <class Tr>
clear();
for(int i=1; i<maxlevel; ++i) {
delete hierarchy[i];
template <class Tr>
void
clear()
for(int i=0;i<maxlevel;++i)
hierarchy[i]->clear();
template <class Tr>
bool
is_valid(bool verbose, int level) const
bool result = true;
// verify correctness of triangulation at all levels
for(int i=0; i<maxlevel; ++i)
result = result && hierarchy[i]->is_valid(verbose, level);
// verify that lower level has no down pointers
result = result && (it->down() == Vertex_handle());
// verify that other levels has down pointer and reciprocal link is fine
result = result && &*(it) == &*(it->down()->up());
for(int k=0; k<maxlevel-1; ++k)
for( Finite_vertices_iterator it = hierarchy[k]->finite_vertices_begin(),
end = hierarchy[k]->finite_vertices_end(); it != end; ++it)
result = result && ( it->up() == Vertex_handle() ||
&*it == &*(it->up())->down() );
return result;
template <class Tr>
typename Triangulation_hierarchy_3<Tr>::Vertex_handle
insert(const Point &p, Cell_handle start)
Locate_type lt;
int i, j;
// locate using hierarchy
locs positions[maxlevel];
locate(p, lt, i, j, positions, start);
// insert at level 0
Vertex_handle vertex = hierarchy[0]->insert(p,
positions[0].lt,
positions[0].pos,
positions[0].li,
positions[0].lj);
Vertex_handle previous = vertex;
Vertex_handle first = vertex;
int level = 1;
while (level <= vertex_level ){
if (positions[level].pos == Cell_handle())
vertex = hierarchy[level]->insert(p);
else
vertex = hierarchy[level]->insert(p,
positions[level].lt,
positions[level].pos,
positions[level].li,
positions[level].lj);
set_up_down(vertex, previous);
previous=vertex;
level++;
return first;
template <class Tr>
insert_and_give_new_cells(const Point &p, OutputItCells fit, Cell_handle
start)
Locate_type lt;
int i, j;
Vertex_handle vertex = hierarchy[0]->insert_and_give_new_cells(p,
positions[0].lt,
positions[0].pos,
positions[0].li,
positions[0].lj,fit);
int level = 1;
else
previous=vertex;
level++;
return first;
template <class Tr>
insert(const Point &p, Locate_type lt, Cell_handle loc, int li, int lj)
Vertex_handle vertex = hierarchy[0]->insert(p,lt,loc,li,lj);
if (vertex_level > 0) {
Locate_type lt;
int i, j;
locate(p, lt, i, j, positions, vertex->cell());
int level = 1;
else
previous=vertex;
level++;
return first;
template <class Tr>
insert_and_give_new_cells(const Point &p, Locate_type lt, Cell_handle loc,
int li, int lj, OutputItCells fit)
hierarchy[0]->insert_and_give_new_cells(p,lt,loc,li,lj,fit);
Locate_type lt;
int i, j;
int level = 1;
else
previous=vertex;
level++;
return first;
template <class Tr>
void
CGAL_triangulation_precondition(v != Vertex_handle());
for (int l = 0; l < maxlevel; ++l) {
Vertex_handle u = v->up();
hierarchy[l]->remove(v);
if (u == Vertex_handle())
break;
v = u;
template <class Tr>
void
remove_and_give_new_cells(Vertex_handle v, OutputItCells fit)
CGAL_triangulation_precondition(!is_infinite(v));
if(l) hierarchy[l]->remove(v);
else hierarchy[l]->remove_and_give_new_cells(v, fit);
break;
v = u;
Vertex_handle old, ret;
for (std::size_t l = 0; l < maxlevel; ++l) {
Vertex_handle w = hierarchy[l]->move_point(v, p);
if (l == 0) {
ret = w;
else {
set_up_down(w, old);
break;
old = w;
v = u;
return ret;
#endif
template <class Tr>
move_if_no_collision(Vertex_handle v, const Point & p)
CGAL_triangulation_precondition(!this->is_infinite(v));
if(v->point() == p) return v;
Vertex_handle ans;
if(l) hierarchy[l]->move_if_no_collision(v, p);
else ans = hierarchy[l]->move_if_no_collision(v, p);
if(ans != v) return ans;
break;
v = u;
return ans;
template <class Tr>
move(Vertex_handle v, const Point & p)
Vertex_handle w = move_if_no_collision(v,p);
if(w != v) {
remove(v);
return w;
return v;
template <class Tr>
Vertex_handle v, const Point & p, OutputItCells fit)
Vertex_handle ans;
else ans =
hierarchy[l]->move_if_no_collision_and_give_new_cells(v, p, fit);
break;
v = u;
return ans;
template <class Tr>
inline
typename Triangulation_hierarchy_3<Tr>::Cell_handle
locate(const Point& p, Locate_type& lt, int& li, int& lj, Cell_handle start)
const
if (start != Cell_handle ())
return Tr_Base::locate (p, lt, li, lj, start);
locate(p, lt, li, lj, positions);
return positions[0].pos;
template <class Tr>
inline
locate(const Point& p, Cell_handle start) const
return Tr_Base::locate (p, start);
Locate_type lt;
int li, lj;
return locate(p, lt, li, lj);
template <class Tr>
void
locs pos[maxlevel], Cell_handle start) const
int level = maxlevel;
// find the highest level with enough vertices
while (hierarchy[--level]->number_of_vertices() < (size_type) minsize) {
if ( ! level)
break; // do not go below 0
for (int i=level+1; i<maxlevel; ++i)
pos[i].pos = Cell_handle();
Cell_handle position = Cell_handle();
while(level > 0) {
// locate at that level from "position"
// result is stored in "position" for the next level
pos[level].pos = position = hierarchy[level]->locate(p,
pos[level].lt,
pos[level].li,
pos[level].lj,
position);
// find the nearest vertex.
Vertex_handle nearest = hierarchy[level]->nearest_vertex_in_cell(p,
position);
// go at the same vertex on level below
nearest = nearest->down();
position = nearest->cell(); // incident cell
--level;
if (start != Cell_handle())
position = start;
pos[0].pos = hierarchy[0]->locate(p, lt, li, lj, position); // at level 0
pos[0].lt = lt;
pos[0].li = li;
pos[0].lj = lj;
template <class Tr>
nearest_vertex(const Point& p, Cell_handle start) const
return Tr_Base::nearest_vertex(p, start != Cell_handle() ? start :
locate(p));
template <class Tr>
int
random_level()
boost::geometric_distribution<> proba(1.0/ratio);
boost::variate_generator<boost::rand48&, boost::geometric_distribution<> >
die(random, proba);
return (std::min)(die(), (int)maxlevel)-1;
} //namespace CGAL
#endif // CGAL_TRIANGULATION_HIERARCHY_3_H
- [cgal-discuss] Extracting triangulation from alpha shape, rcasero, 08/01/2013
- Re: [cgal-discuss] Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/05/2013
- Re: [cgal-discuss] Re: Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/05/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/06/2013
