- To:
- Subject: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
- Date: Mon, 17 Mar 2014 05:33:02 -0700 (PDT)
I am trying to create a STL map of type map<int,CGAL::AABB_tree<Traits>>
(map of AABB tree's) when I try to assign a value to the map, for example
(this code is only for demonstration purposes):
//CGAL includes begin
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/AABB_face_graph_triangle_primitive.h>
//CGAL includes end
* CGAL typedef's for initialization
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
typedef K::Point_3 Point_3;
typedef K::Segment_3 Segment;
typedef CGAL::Polyhedron_3<K> Polyhedron;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef Polyhedron::Vertex_const_iterator
Vertex_const_iterator;
typedef Polyhedron::Facet_const_iterator
Facet_const_iterator;
typedef Polyhedron::Halfedge_around_facet_const_circulator
Halfedge_around_facet_const_circulator;
typedef CGAL::AABB_face_graph_triangle_primitive<Polyhedron> Primitive;
typedef CGAL::AABB_traits<K, Primitive> Traits;
typedef CGAL::AABB_tree<Traits> Tree;
typedef Tree::Point_and_primitive_id
Point_and_primitive_id;
//end of typedef's
BuildMesh<HalfedgeDS> mesh(V, F);
polyhedron.delegate( mesh);
myMap[someInt] =
Tree(polyhedron.facets_begin(),polyhedron.facets_end(),polyhedron);
I get the following error:
error C2248: 'CGAL::AABB_tree< AABBTraits >::operator =' : cannot access
private member declared in class 'CGAL::AABB_tree< AABBTraits>'
I tried looking in the source code of CGAL and found in CGAL\AABB_tree.h the
following lines:
private:
// Disabled copy constructor & assignment operator
typedef AABB_tree<AABBTraits> Self;
AABB_tree(const Self& src);
Self& operator=(const Self& src);
this means that the copy and assignment constructors are private, thus it's
not possible to create stl containers of type Tree.
I tried to use pointers instead I changed my map to map<int,CGAL::AABB_tree
< Traits > * > and tried:
myMap[someInt] = new
but then it crashed my code.
Is there any way around it so it will be possible to create an STL container
of this type?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/can-t-create-stl-containers-of-type-AABB-tree-in-CGAL-tp4658973.html
- [cgal-discuss] can't create stl containers of type AABB tree in CGAL, dontcarebear, 03/17/2014
- Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL, Zohar, 03/17/2014
- Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL, dontcarebear, 03/17/2014
