cgal-discuss - Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
  • To:
  • Subject: Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
  • Date: Mon, 17 Mar 2014 06:37:03 -0700 (PDT)
Tried debugging it crashed spontaneously before running the command that uses
the pointer (it points me to the Half edge data structure) . even a very
simple program that replaces the AABB tree with a pointer to the tree
crashes.
I find it weird that it's so hard creating a map (or any other STL
container) of type AABB Tree.
I think that it is tied to the problem of assigning the tree to the map.
p.s the stack overflow post is mine to, and the solution there didn't help
too...
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/can-t-create-stl-containers-of-type-AABB-tree-in-CGAL-tp4658973p4658975.html
