- To:
- Subject: Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
- Date: Mon, 17 Mar 2014 09:02:33 -0700 (PDT)
I did try to use static map of AABB tree pointers and it is the cause of the
crashes of course :P
The problem is how can I serialize a AABB Tree (or more problematic a whole
stl map of such...)
I tried
myMap.emplace(
std::piecewise_construct,
std::forward_as_tuple(idCount),
std::forward_as_tuple());
when map is map<int,Tree> myMap;
to construct empty trees in my map but I still get the error:
error C2248: 'CGAL::AABB_tree<AABBTraits>::AABB_tree' : cannot access
private member declared in class 'CGAL::AABB_tree<AABBTraits>'
I am trying to find a workaround but it's tricky.
Thanks for the help!!!!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/can-t-create-stl-containers-of-type-AABB-tree-in-CGAL-tp4658973p4658980.html
- [cgal-discuss] can't create stl containers of type AABB tree in CGAL, dontcarebear, 03/17/2014
- Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL, Zohar, 03/17/2014
- Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL, dontcarebear, 03/17/2014
