- To:
- Subject: Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
- Date: Mon, 17 Mar 2014 09:29:24 -0700 (PDT)
Please let me be more specific:
1. There is a default constructor for AABB, so there's no problem with:
map<int, AABB_tree> i2t;
Then populate a tree:
map<int, AABB_tree>::iterator it;
it->rebuild(..);
with another tree sequence.
2. By shared memory I mean:
http://msdn.microsoft.com/en-us/library/windows/desktop/aa366551%28v=vs.85%29.aspx
Allocate enough memory for your tree, cast the pointer to AABB*, populate it
(using rebuild), and it would live beyond your .mex.
3. Second option use:
http://www.boost.org/doc/libs/1_55_0/libs/serialization/doc/tutorial.html
To save your tree, and then load it again.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/can-t-create-stl-containers-of-type-AABB-tree-in-CGAL-tp4658973p4658981.html
- [cgal-discuss] can't create stl containers of type AABB tree in CGAL, dontcarebear, 03/17/2014
- Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL, Zohar, 03/17/2014
- Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL, dontcarebear, 03/17/2014
