cgal-discuss - Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
  • To:
  • Subject: Re: [cgal-discuss] can't create stl containers of type AABB tree in CGAL
  • Date: Mon, 17 Mar 2014 08:28:25 -0700 (PDT)
Just to emphasize: Don't use static or other nonsense. A mex is a .dll, and
when it unloads the memory is freed. So use shared memory, which persists
after a process ends, and a few processes can access it. You can also use
boost::serialize to save/load your data between calls.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/can-t-create-stl-containers-of-type-AABB-tree-in-CGAL-tp4658973p4658979.html
