- To:
- Subject: Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?
- Date: Sun, 13 Apr 2014 00:07:00 -0700 (PDT)
Hi Zohar,
Do you mean the Carve here?
http://code.google.com/p/carve/downloads/list
I have tried it long time ago but failed to compile the project.
Could you please give me a simple example to do the Boolean operation on
this kind of unclosed polyhedron?
Thanks,
Tang Laoya
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-operations-between-unclosed-polyhedrons-tp4659114p4659121.html
- [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/15/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/16/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Andreas Fabri, 04/16/2014
