- To:
- Subject: Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?
- Date: Sun, 13 Apr 2014 09:02:44 -0700 (PDT)
So you don't want boolean intersection you want boolean difference. My half
planes intersection ides won't work for both cases, I looked at it wrongly.
But carve lib can do your example, see below (was done with the maya wrapper
boolPro). On tips how to build and use carve lib try to go over the
following open source maya plugin wrapper boolPro:
http://forums.cgsociety.org/showthread.php?t=1041117
a1 - a2:
OFF
26 26 0
4.08407 -1 0.333333
5.08407 0 2
4.08407 1 -1
4.08407 0 1
4.08407 2 -2
4.08407 0 -2
4.08407 1 0.333333
5.08407 0 -1
4.08407 0 2
4.08407 -2 0
4.08407 -1 1
4.08407 -0.333333 -1
4.08407 2 0
4.58407 0 1
5.08407 0 1
5.08407 0 -2
4.08407 -0.333333 1
4.08407 0 -1
4.08407 -2 -2
4.08407 -1 -1
4.08407 1 0
4.08407 -2 2
4.58407 0 -1
4.08407 -1 0
4.08407 2 2
4.08407 1 1
3 20 12 24
3 20 24 25
3 20 25 6
3 2 4 12
3 2 12 20
3 25 24 8
3 25 8 3
3 17 5 4
3 17 4 2
3 3 8 21
3 3 21 10
3 3 10 16
3 10 21 9
3 10 9 23
3 10 23 0
3 23 9 18
3 23 18 19
3 19 18 5
3 19 5 17
3 19 17 11
3 3 8 1
3 3 1 13
3 13 1 14
3 7 15 22
3 22 15 5
3 22 5 17
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-operations-between-unclosed-polyhedrons-tp4659114p4659123.html
- [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/15/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/16/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Andreas Fabri, 04/16/2014
