- To:
- Subject: Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?
- Date: Mon, 14 Apr 2014 11:08:10 -0700 (PDT)
Sorry, I didn't fully get that, please explain again.
What do you mean by multi-domain polyhedron? Polyhedron_3 is a 2-manifold
and it can have multiple components. If you mean that it has volume with
inner spaces, then you probably need tets (mesh_3). The example you provided
just contains an open mesh (is it even a manifold?) and a box. Maybe you
should provide a better example.
If you define your shapes as zero level sets a distance function, I think
that bool ops should be straight forward, and then you could extract a mesh.
Tell me if you don't understand what I mean.
CGAL should be able to perform bool ops on multi-component surfaces.
Otherwise, just do it component at time.
I'm not sure about carve lib capabilities. But if you want me to test
something, then provide meshes.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-operations-between-unclosed-polyhedrons-tp4659114p4659135.html
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, (continued)
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/15/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/16/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Andreas Fabri, 04/16/2014
