cgal-discuss - Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?
  • To:
  • Subject: Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?
  • Date: Sun, 13 Apr 2014 09:24:59 -0700 (PDT)
While carve lib can work with general polyhedron, MeshLab exported the .off
to .obj (for maya) as triangle meshes (I can fix that if necessary). Maybe
you should try working with triangle meshes.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-operations-between-unclosed-polyhedrons-tp4659114p4659124.html
