- To:
- Subject: Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?
- Date: Sun, 13 Apr 2014 01:12:13 -0700 (PDT)
Hi Zohar,
I noticed the example "test_carve_polyhedrons_2" is similar to what I
needed. However, the example crashed with the following error message:
WARNING! <0,0,0>==<0,0,1.0230769175768134e-008>
FACE LOOP ERROR: 0000000000AE3A10-0000000000EC0080 : 1
FACE LOOP ERROR: 0000000000AE3A60-0000000000EC00A8 : 1
FACE LOOP ERROR: 0000000000AE3A10-0000000000EC00A8 : -1
FACE LOOP ERROR: 0000000000AE3A38-0000000000EC0080 : -1
FACE LOOP ERROR: 0000000000AE3A38-0000000000AE3A60 : 1
Do you have any such kind of example that can run successfully?
Thanks,
Tang Laoya
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-operations-between-unclosed-polyhedrons-tp4659114p4659122.html
- [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/13/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Zohar, 04/14/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/15/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, tang, 04/16/2014
- Re: [cgal-discuss] Boolean operations between unclosed polyhedrons?, Andreas Fabri, 04/16/2014
