- To:
- Subject: Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
- Date: Fri, 7 Nov 2014 08:31:10 +0100
Hi Adam,
I'm didn't test run it on my computer, but
D3->tds().delete_cell(cit);
compiles for me.
/Per
On Fri, Nov 7, 2014 at 5:12 AM, Adam Getchell
wrote:
> Hello all,
> I have a function on a Delaunay triangulation which checks the validity of
> my cells. I want to call TriangulationDataStructure_3::delete_cell(). How do
> I do that?
> First, I tried just doing Tds::delete_cell(cit);
> But that gives a “call to non-static member function without an object
> argument”.
> Next, I tried calling the superclass method from the subclass:
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> /// Used so that each timeslice is assigned an integer
> typedef CGAL::Triangulation_3<K> Triangulation;
> typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
> typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
> typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
> typedef Delaunay::Vertex_handle Vertex_handle;
> typedef Delaunay::Locate_type Locate_type;
> typedef Delaunay::Point Point;
> inline bool check_timeslices(Delaunay* D3) {
> Delaunay::Finite_cells_iterator cit;
> for(cit = D3->finite_cells_begin(); cit != D3->finite_cells_end(); ++cit)
> /// Get the vertices from the cell
> //Delaunay::Facet& face = *(cit->first);
> // Vertex_handle vs = cit->source();
> if (cit->is_valid())
> std::cout << "Cell is valid." << std::endl;
> else
> D3->Tds::delete_cell(cit);
> std::cout << "Invalid cell destroyed." << std::endl;
> assert(D3->is_valid());
> return true;
> It looks like delete_cell is a private function not callable from
> subclasses. I get:
> [ 12%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
> In file included from /Users/adam/CDT-plusplus/src/cdt.cpp:22:
> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:13: error: 'Tds' is a
> private
> member of 'CGAL::Triangulation_3<CGAL::Epick,
> CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
> int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
> CGAL::Triangulation_ds_vertex_base_3<void> > >,
> CGAL::Triangulation_ds_cell_base_3<void>, CGAL::Sequential_tag>,
> CGAL::Default>'
> /usr/local/include/CGAL/Triangulation_3.h:375:83: note: implicitly declared
> private here
> ...Triangulation_cell_base_3<GT> > >::type Tds;
> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:18: error:
> 'CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
> CGAL::Sequential_tag>::delete_cell' is not a member of class
> 'Delaunay'
> (aka 'Delaunay_triangulation_3<K, Tds>')
> Adam Getchell
> about.me/adamgetchell
- [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Adam Getchell, 11/07/2014
- Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Per Zetterlund, 11/07/2014
- Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Adam Getchell, 11/07/2014
- <Possible follow-up(s)>
