- To:
- Subject: Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
- Date: Thu, 6 Nov 2014 23:41:59 -0800
Hi Per,
Wow! That compiles! Now I’m confused. Where is tds() defined?
I had been using the Tds from the:
typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
Also, I looked at the documentation and realized I could delete vertices, so
I was doing:
for(size_t i = 0; i < 4; i++)
/// Remove all vertices in the invalid cell
D3->remove(cit->vertex(i));
Thank you for your answer, sorry about the further question!
Adam Getchell
about.me/adamgetchell
> On Nov 6, 2014, at 11:31 PM, Per Zetterlund
> wrote:
> Hi Adam,
> I'm didn't test run it on my computer, but
> D3->tds().delete_cell(cit);
> compiles for me.
> /Per
> On Fri, Nov 7, 2014 at 5:12 AM, Adam Getchell
> wrote:
>> Hello all,
>> I have a function on a Delaunay triangulation which checks the validity of
>> my cells. I want to call TriangulationDataStructure_3::delete_cell(). How
>> do
>> I do that?
>> First, I tried just doing Tds::delete_cell(cit);
>> But that gives a “call to non-static member function without an object
>> argument”.
>> Next, I tried calling the superclass method from the subclass:
>> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
>> /// Used so that each timeslice is assigned an integer
>> typedef CGAL::Triangulation_3<K> Triangulation;
>> typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
>> typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
>> typedef Delaunay::Vertex_handle Vertex_handle;
>> typedef Delaunay::Locate_type Locate_type;
>> typedef Delaunay::Point Point;
>> inline bool check_timeslices(Delaunay* D3) {
>> Delaunay::Finite_cells_iterator cit;
>> for(cit = D3->finite_cells_begin(); cit != D3->finite_cells_end(); ++cit)
>> /// Get the vertices from the cell
>> //Delaunay::Facet& face = *(cit->first);
>> // Vertex_handle vs = cit->source();
>> if (cit->is_valid())
>> std::cout << "Cell is valid." << std::endl;
>> else
>> D3->Tds::delete_cell(cit);
>> std::cout << "Invalid cell destroyed." << std::endl;
>> assert(D3->is_valid());
>> return true;
>> It looks like delete_cell is a private function not callable from
>> subclasses. I get:
>> [ 12%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
>> In file included from /Users/adam/CDT-plusplus/src/cdt.cpp:22:
>> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:13: error: 'Tds' is a
>> private
>> member of 'CGAL::Triangulation_3<CGAL::Epick,
>> CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
>> int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
>> CGAL::Triangulation_ds_vertex_base_3<void> > >,
>> CGAL::Triangulation_ds_cell_base_3<void>, CGAL::Sequential_tag>,
>> CGAL::Default>'
>> /usr/local/include/CGAL/Triangulation_3.h:375:83: note: implicitly declared
>> private here
>> ...Triangulation_cell_base_3<GT> > >::type Tds;
>> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:18: error:
>> 'CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
>> CGAL::Sequential_tag>::delete_cell' is not a member of class
>> 'Delaunay'
>> (aka 'Delaunay_triangulation_3<K, Tds>')
>> Adam Getchell
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Adam Getchell, 11/07/2014
- Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Per Zetterlund, 11/07/2014
- Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Adam Getchell, 11/07/2014
- <Possible follow-up(s)>
