- To:
- Subject: Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
- Date: Fri, 7 Nov 2014 08:59:39 +0100
Hi Adam,
It's defined in Triangulation_3.h (line 395 in my system).
Docs is here:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#a8330f902e49d6280b4a6a498fa4d925a
/Per
On Fri, Nov 7, 2014 at 8:41 AM, Adam Getchell
wrote:
> Hi Per,
> Wow! That compiles! Now I’m confused. Where is tds() defined?
> I had been using the Tds from the:
> typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
> Also, I looked at the documentation and realized I could delete vertices,
> so I was doing:
> for(size_t i = 0; i < 4; i++)
> /// Remove all vertices in the invalid cell
> D3->remove(cit->vertex(i));
> Thank you for your answer, sorry about the further question!
> Adam Getchell
> about.me/adamgetchell
>> On Nov 6, 2014, at 11:31 PM, Per Zetterlund
>> wrote:
>> Hi Adam,
>> I'm didn't test run it on my computer, but
>> D3->tds().delete_cell(cit);
>> compiles for me.
>> /Per
>> On Fri, Nov 7, 2014 at 5:12 AM, Adam Getchell
>> wrote:
>>> Hello all,
>>> I have a function on a Delaunay triangulation which checks the validity of
>>> my cells. I want to call TriangulationDataStructure_3::delete_cell(). How
>>> do
>>> I do that?
>>> First, I tried just doing Tds::delete_cell(cit);
>>> But that gives a “call to non-static member function without an object
>>> argument”.
>>> Next, I tried calling the superclass method from the subclass:
>>> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
>>> /// Used so that each timeslice is assigned an integer
>>> typedef CGAL::Triangulation_3<K> Triangulation;
>>> typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
>>> typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
>>> typedef Delaunay::Vertex_handle Vertex_handle;
>>> typedef Delaunay::Locate_type Locate_type;
>>> typedef Delaunay::Point Point;
>>> inline bool check_timeslices(Delaunay* D3) {
>>> Delaunay::Finite_cells_iterator cit;
>>> for(cit = D3->finite_cells_begin(); cit != D3->finite_cells_end();
>>> ++cit)
>>> /// Get the vertices from the cell
>>> //Delaunay::Facet& face = *(cit->first);
>>> // Vertex_handle vs = cit->source();
>>> if (cit->is_valid())
>>> std::cout << "Cell is valid." << std::endl;
>>> else
>>> D3->Tds::delete_cell(cit);
>>> std::cout << "Invalid cell destroyed." << std::endl;
>>> assert(D3->is_valid());
>>> return true;
>>> It looks like delete_cell is a private function not callable from
>>> subclasses. I get:
>>> [ 12%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
>>> In file included from /Users/adam/CDT-plusplus/src/cdt.cpp:22:
>>> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:13: error: 'Tds' is a
>>> private
>>> member of 'CGAL::Triangulation_3<CGAL::Epick,
>>> CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
>>> int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
>>> CGAL::Triangulation_ds_vertex_base_3<void> > >,
>>> CGAL::Triangulation_ds_cell_base_3<void>, CGAL::Sequential_tag>,
>>> CGAL::Default>'
>>> /usr/local/include/CGAL/Triangulation_3.h:375:83: note: implicitly
>>> declared
>>> private here
>>> ...Triangulation_cell_base_3<GT> > >::type Tds;
>>> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:18: error:
>>> 'CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
>>> CGAL::Sequential_tag>::delete_cell' is not a member of class
>>> 'Delaunay'
>>> (aka 'Delaunay_triangulation_3<K, Tds>')
>>> Adam Getchell
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Adam Getchell, 11/07/2014
- Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Per Zetterlund, 11/07/2014
- Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation, Adam Getchell, 11/07/2014
- <Possible follow-up(s)>
