cgal-discuss - Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
  • Date: Fri, 7 Nov 2014 00:43:00 -0800
Thank you!
Adam Getchell
about.me/adamgetchell
> On Nov 6, 2014, at 11:59 PM, Per Zetterlund
> wrote:
> Hi Adam,
> It's defined in Triangulation_3.h (line 395 in my system).
> Docs is here:
> http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#a8330f902e49d6280b4a6a498fa4d925a
> /Per
> On Fri, Nov 7, 2014 at 8:41 AM, Adam Getchell
> wrote:
>> Hi Per,
>> Wow! That compiles! Now I’m confused. Where is tds() defined?
>> I had been using the Tds from the:
>> typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
>> Also, I looked at the documentation and realized I could delete vertices,
>> so I was doing:
>> for(size_t i = 0; i < 4; i++)
>> /// Remove all vertices in the invalid cell
>> D3->remove(cit->vertex(i));
>> Thank you for your answer, sorry about the further question!
>> Adam Getchell
>>> On Nov 6, 2014, at 11:31 PM, Per Zetterlund
>>> wrote:
>>> Hi Adam,
>>> I'm didn't test run it on my computer, but
>>> D3->tds().delete_cell(cit);
>>> compiles for me.
>>> /Per
>>> On Fri, Nov 7, 2014 at 5:12 AM, Adam Getchell
>>> wrote:
>>>> Hello all,
>>>> I have a function on a Delaunay triangulation which checks the validity
>>>> of
>>>> my cells. I want to call TriangulationDataStructure_3::delete_cell().
>>>> How do
>>>> I do that?
>>>> First, I tried just doing Tds::delete_cell(cit);
>>>> But that gives a “call to non-static member function without an object
>>>> argument”.
>>>> Next, I tried calling the superclass method from the subclass:
>>>> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
>>>> /// Used so that each timeslice is assigned an integer
>>>> typedef CGAL::Triangulation_3<K> Triangulation;
>>>> typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
>>>> typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
>>>> typedef Delaunay::Vertex_handle Vertex_handle;
>>>> typedef Delaunay::Locate_type Locate_type;
>>>> typedef Delaunay::Point Point;
>>>> inline bool check_timeslices(Delaunay* D3) {
>>>> Delaunay::Finite_cells_iterator cit;
>>>> for(cit = D3->finite_cells_begin(); cit != D3->finite_cells_end();
>>>> ++cit)
>>>> /// Get the vertices from the cell
>>>> //Delaunay::Facet& face = *(cit->first);
>>>> // Vertex_handle vs = cit->source();
>>>> if (cit->is_valid())
>>>> std::cout << "Cell is valid." << std::endl;
>>>> else
>>>> D3->Tds::delete_cell(cit);
>>>> std::cout << "Invalid cell destroyed." << std::endl;
>>>> assert(D3->is_valid());
>>>> return true;
>>>> It looks like delete_cell is a private function not callable from
>>>> subclasses. I get:
>>>> [ 12%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
>>>> In file included from /Users/adam/CDT-plusplus/src/cdt.cpp:22:
>>>> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:13: error: 'Tds' is a
>>>> private
>>>> member of 'CGAL::Triangulation_3<CGAL::Epick,
>>>> CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
>>>> int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
>>>> CGAL::Triangulation_ds_vertex_base_3<void> > >,
>>>> CGAL::Triangulation_ds_cell_base_3<void>, CGAL::Sequential_tag>,
>>>> CGAL::Default>'
>>>> /usr/local/include/CGAL/Triangulation_3.h:375:83: note: implicitly
>>>> declared
>>>> private here
>>>> ...Triangulation_cell_base_3<GT> > >::type Tds;
>>>> /Users/adam/CDT-plusplus/src/S3Triangulation.h:59:18: error:
>>>> 'CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
>>>> CGAL::Sequential_tag>::delete_cell' is not a member of class
>>>> 'Delaunay'
>>>> (aka 'Delaunay_triangulation_3<K, Tds>')
>>>> Adam Getchell
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://sympa.inria.fr/sympa/info/cgal-discuss
