- To:
- Subject: Re: [cgal-discuss] Merge polylines
- Date: Tue, 25 Aug 2015 21:23:40 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:FufhhR1Rk2RdoW4+smDT+DRfVm0co7zxezQtwd8ZsegRKvad9pjvdHbS+e9qxAeQG96LsLQZ2qGH7ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6JyZnmnLHss7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y5WdmwLiBdOH0D/7Rf3V4q58gDVn8469ySdOMDqV6EaUD++6L16CVWg3CMOKiQ09n2RkM12gatGiBmurhg5xJTbNtLGfMFid7/QKItJDVFKWdxcAnRM
Le lundi 24 août 2015 14:05:05 Bryn Lloyd a écrit :
> Dear Sebastien
> I attached the surface and polylines as code sample (C-arrays), but can
> also provide other formats if that is easier for you.
> Thanks & best regards
Hi Bryn,
I know what is wrong in that input data.
At the points (29, -39, 0), (29, -39, 18), there are two line segments that
pass through those points in their interior. You must split those two line
segments so that in the end the polylines (here, only line segments) only
intersect at their extremities.
Otherwise, the polylines appear as non-adjacent combinatorially, whereas they
intersect geometrically. And the 1D mesher of CGAL Mesh_3 tries to separate
the non-adjacent polylines, and cannot do that because they cannot be
separated geometrically.
Laurent Rineau, PhD
- [cgal-discuss] Make mesh with features: feature lines duplicated, overlapping or very close, Bryn Lloyd, 08/20/2015
- [cgal-discuss] Merge polylines, Bryn Lloyd, 08/21/2015
- Re: [cgal-discuss] Merge polylines, Sebastien Loriot (GeometryFactory), 08/24/2015
- Re: [cgal-discuss] Merge polylines, Bryn Lloyd, 08/24/2015
- Re: [cgal-discuss] Merge polylines, Laurent Rineau (CGAL/GeometryFactory), 08/25/2015
