cgal-discuss - Re: [cgal-discuss] Isosurfaces from Gray level image
  • To:
  • Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
  • Date: Fri, 2 Oct 2015 18:03:47 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:AMPyghL66oyGoL0/EdmcpTZWNBhigK39O0sv0rFitYgULfjxwZ3uMQTl6Ol3ixeRBMOAu64C1bad4/yocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC04Lpi6vip9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD88Qa6tVYXK7mU6M9RL1eRHR6YiFmrPHs4BLMRA/K6noHWXgNiTJJBRLE5Vf0RMTfqCz/48h03iTSAcrrV7YzWC/qu6ViThKulCAaLTg+8Xr/hcF3ia9HugOvrhdjxJTFJoqSMawtLevmYdoGSD8ZDY5qXCtbD9bgPoY=
Hi Alexandre,
I have been playing around with your data and I am not experiencing such a bad behavior of Mesh_3.
I based my test on mesh_3D_image.cpp (the one you can find in the latest releases), and changed the meshing criteria.
This example ran on your 300*300 example
with
> Mesh_criteria criteria(facet_angle = 30, facet_size = 10, facet_distance = 1);
(which is quite coarse, for sure, and there is no criterion on cells here)
generates a mesh of ~184,000 vertices in ~30 seconds.
What quality criterion are you requiring?
Best,
Jane.
Le 25/09/2015 17:50, Alexandre Lapene a écrit :
HI Jane,
Thanks for your quick answer.
I don't remember... probably a few millions but I'm not sure.
Surface_mesh also crashed "not enough memory". I have 32Gb on my desktop.
Here are two files:
- 50x50x50 sample. I managed to generate a volume and surface mesh for this
one.
https://stanford.box.com/s/t02oc4amgpqdhz1hn69cara5nxdfqp3i
- 300x300x300 sample.
https://stanford.box.com/s/ktx9pi7yjg0lpka3k1pkmbd37gquxp6l
Please note that the gray levels are either 0 or 255 on these examples.
Thanks again
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661163.html
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
