- To:
- Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
- Date: Fri, 2 Oct 2015 14:22:30 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:FSnOMh3WP3VhnJ0PsmDT+DRfVm0co7zxezQtwd8ZsegSKfad9pjvdHbS+e9qxAeQG96Lt7Qa1qGO6OjJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6OyZrqnLjps7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y41VmgGmxxEGQWNyBjiU5H8+n/+v/Jw3iSyJtH/S74zQzjk4qt2Hky7wBwbPiI0pTmEwvd7i7hW9Uqs
Hi Jane,
Thanks for your answer. My bad. My problem was the verbosity. I turned on
CGAL_MESH_3_VERBOSE, and displaying was just killing the everything.
So, it runs fast with your parameters.
That brings me to another question: how can I turn on a low verbose mode,
just to have an idea of what's going on.
Thanks
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661182.html
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/02/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/02/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/03/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/05/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/05/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/06/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/06/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/08/2015
