cgal-discuss - Re: [cgal-discuss] Isosurfaces from Gray level image
  • To:
  • Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
  • Date: Thu, 8 Oct 2015 10:39:59 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:vgW/SxJB/ltYP+IrS9mcpTZWNBhigK39O0sv0rFitYgULvTxwZ3uMQTl6Ol3ixeRBMOAu64C1LeempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRsiN0oye7KObxd76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsP0o84tMUL7xYr8jZb1eFjUvdW4vt+PxshyWbwKJ6zMgVXgMlB1JGECR7hj8U9HttTbgsO18wwGVMMrzQKwuSDqr5LtsUg6ugyACYW1quFrLg9B92foI6CmqoAZyltbZ
Hi Alexandre,
facet_distance is, for a "restricted Delaunay" facet, the desired upper bound on
the absolute distance between the circumcenter of the facet, and surface.
This distance is computed as the distance between the circumcenter and the intersection of the facet dual (ray or segment) with the surface.
So as facet_distance gets smaller, facets indeed become more horizontal/vertical, but I'm afraid you will still get approximations in the corners of the voxels.
You can also provide the mesher with polylines to be "protected", i.e. present in the output mesh. If you provide as "sharp features" the edges of the cube [0,0] x [L,L] you can make sure they will be in the output mesh (maybe refined, but still rectilinear).
Hope it helps!
Best,
Jane.
Le 06/10/2015 17:13, Alexandre Lapene a écrit :
Hi Jane,
Thanks for your quick reply.
There are two reasons why I'm trying to use small values for facet_distance.
The first one is I'm not sure of the definition of facet_distance. I had
assumed it was a relative value, likely based on the domain size, diagonal.
Also while reducing this value below the theoretical minimum value you
mention, I noticed improvement in the quality of the surface mesh. It is an
absolute distance?
Second reason is I also want to have very flat surfaces for my bounding box
surfaces (squares) as that would make my life easier for simulation. To tell
you the entire story, I ultimately need to give separate attributes for the
boundaries and one way is by detecting, after meshing, x=0,x=L,y=0,y=L
etc... faces. So if you have an alternative I'm more than interested.
Thanks!
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661200.html
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
