- To:
- Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
- Date: Mon, 5 Oct 2015 13:04:02 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:KZ/m7hOVLg2/V70qyD4l6mtUPXoX/o7sNwtQ0KIMzox0KPj+rarrMEGX3/hxlliBBdydsKIYzbSG+Pm8BSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTrkb7isMSPP01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBDux5FEwHD4Av3FrP4qib8u6Ip3CCCMMv7ZasoUDKs6L1nDhLklXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hi Jane,
Thanks for your answer.
The size of a voxel is 1 for this data set. In reality it's much smaller and
does work well if I use the real dimension, I think it's 10^-6.
What is strange is the smaller sample I have provided 50x50x50 works well
for facet_distance up to 10^-5 with same voxel size. Do you think there is
a scaling issue? I will try with normalize sample to avoid precision
effects.
Best regards,
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661195.html
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/02/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/02/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/03/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/05/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/05/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/06/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/06/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/08/2015
