cgal-discuss - Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • To:
  • Subject: Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • Date: Wed, 28 Oct 2015 20:17:41 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:RRls9R8MMtROkf9uRHKM819IXTAuvvDOBiVQ1KB92+kcTK2v8tzYMVDF4r011RmSDdidsq0P1LKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lR8iL0I/oj6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYhvQ66sQVUbnmZ79qCvtDHTE+OiY04tfqvF/NV0yU934EWyIXlBRPRAPK5RW/UpbquTbhrblB33yRMsTyCLw1Qj+/9LxDSRnyiS5BOSRq3nvQj5mIdFoT9Bi8oh15zJfVfamaMfN/euXWetZMFjkJZdpYSyEUWtD0VIAIFedUZes=
Thanks for your kind replies.
Finally, I am planning to implement this feature by my self to solve my
problem.
2015-10-28 1:49 GMT-07:00 Phil Weir
> Hello,
> On 10/28/2015 03:26 AM, 郑银河 wrote:
>> I am trying to do 3D constrained Delaunay triangulation using CGAL.
>> The domain is described using Piecewise Linear Complexes (PLS) in 3D,
>> i.e., each bounday polygon of the domain is known but the bounday mesh
>> of the domain is not generated . The domain may contain 0d, 1d
>> features.
>> I tried to use the 3D Mesh Generation package to do the job. However,
>> in order to use this package, I should first convert the PLS to a
>> boundary mesh, which is difficult because the PLS may contain
>> unmanifold edges.
>> I am wondering if there is some method in CGAL that can be used to
>> generate the constrained Delaunay triangulation from a set of bounded
>> polygons?
> On the off-chance a less strict volumetric mesh, with a tolerance, rather
> than a constrained Delaunay triangulation, is sufficient, and you can
> formulate an in-out identity function, that might get you somewhere. Not so
> helpful if you need exact matching, of course, or for preserving your
> features, but just to mention it. (Apologies for posting the same suggestion
> on another related topic, but I recall struggling to generate CDTs some time
> before realising the use-case didn't actually require it)
> All the best,
> PTW
> __________________________
> Phil Weir | NUMA Engineering Services Ltd.
> Block 1, Quayside Business Park,
> Mill St, Dundalk,
> Co. Louth, Ireland.
> Tel: +353 42 9395821 | Fax: +353 42 9390220
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
