cgal-discuss - Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • To: cgal-discuss <>
  • Subject: Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • Date: Thu, 29 Oct 2015 21:05:42 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:l3VNDRHJslmZkloB24MONp1GYnF86YWxBRYc798ds5kLTJ74ps2wAkXT6L1XgUPTWs2DsrQf27eQ6vGrADdYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh730osyYOl4QzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3Heb8lR+lYECg+KDJyo9b6sAHKCwqJ/HoVFGsM1QFZBhDMqxD8UJC2uSTzsq9x2TKRINbtHowzDD+t5qMuRB7zgzocLHZt+27ejol8jblQvQm6jx152Y/dJo+PYqlQZKTYKPkXQ2hIW8dXHw9MAoexc8NbBecHP+9drorVvFoLsB+3Qw+rUrC8ggRUj2P7iPVpm98qFhvLiVQt
On 29 October 2015 at 17:45, 郑银河 <> wrote:
Thank you for the reminder @ Olivier Devillers.
I find a package called Tetgen on the web, which can generate the CDT
by adding extra points.
However, that package is implemented using float point number
arithmetic. I am trying to reimplement that package using the exact
arithmetic interface provided in CGAL
Just in case you have overlooked it: Tetgen uses robust predicates. By default it is Shewchuk's predicates, but it can also use CGAL's EPICK kernel. See http://wias-berlin.de/software/tetgen/1.5/doc/manual/manual004.html#sec25 The relevant section is 3.1.4.
(Note that I haven't tried this myself)
Best regards
Benjamin Kehlet
2015-10-29 1:11 GMT-07:00 Olivier Devillers <>:
> Le 29/10/15 04:17, 郑银河 a écrit :
> Thanks for your kind replies.
> Finally, I am planning to implement this feature by my self to solve my
> problem.
> A constrained DT does not always exist in 3D
> (there exists polyhedra that cannot be triangulated using the prescribed
> edges (or faces)
> without adding new vertices [ Schönhardt polyhedron] ).
