cgal-discuss - Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • To:
  • Subject: Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • Date: Thu, 29 Oct 2015 10:30:55 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:H8yYeheWWmzj3fRB3wytMKd9lGMj4u6mDksu8pMizoh2WeGdxc6yZx7h7PlgxGXEQZ/co6odzbGG7ua5CCdRvN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvcSCKFQVzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3Heb8lR+lYECg+KDJyo9b6sAHKCwqJ/HoVFGsM1QFZBhDMqxD8UJC2uSTzsq9x2TKRINbtHowzDD+t5qMuRB7zgzocLBY49nvWg4p+lvF1uhWk8uSHO8aAapyQNfxxZ6LAVdwfTGtFGM1WUnoSUcuHc4ITAr9Zbq5jpI7nqg5WoA==
That is exactly what I think yesterday.
However, In order to use the meshing packages, I should construct the
boundary mesh of the domain, which is pretty difficult because the
boundary mesh may contain nonmainfold edges.
2015-10-29 9:59 GMT-07:00 Olivier Devillers
> Le 29/10/15 17:45, 郑银河 a écrit :
>> Thank you for the reminder @ Olivier Devillers.
>> I find a package called Tetgen on the web, which can generate the CDT
>> by adding extra points.
>> However, that package is implemented using float point number
>> arithmetic. I am trying to reimplement that package using the exact
>> arithmetic interface provided in CGAL
> meshing packages of CGAL should work
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
