cgal-discuss - Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
  • To:
  • Subject: Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
  • Date: Mon, 5 Sep 2016 18:59:01 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:kzx50BS+h4NQHh7BuNv0oUrqPNpsv+yvbD5Q0YIujvd0So/mwa64ZxaN2/xhgRfzUJnB7Loc0qyN4vmmBDxLvMfJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9204IDZNgVUmCKmM/Q1NwSztQyXt88MgIIkJLx20QrMunIPeuJYwiRjKluX2hr9/cyt54UwzyMFsP0o84tMUL7xYr8jZb1eFjUvdW4vt+PxshyWdhaM5mEVUC0tkxxHA0CR9xD8UZe3qTb5tvB02gGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
Hi Sebastien,
 Instead of getting the segment polyhedron and using that to create an ROI, I directly used the segment_map to create the ROI as follows.
 for(Polyhedron::Facet_iterator facet_it = (*polyhedron()).facets_begin();
                facet_it != (*polyhedron()).facets_end(); ++facet_it)
            if(segment_property_map[facet_it] == segid)// the particular seg id I want as ROI
                //Let's take the three vertices of facet
                insert_roi_vertex(facet_it->halfedge()->vertex());
                insert_roi_vertex(facet_it->halfedge()->next()->vertex());
                insert_roi_vertex(facet_it->halfedge()->opposite()->vertex());
I do get a correct ROI as seen form its vizulization, but have a doubt iterating in this way will push same shared vertex among faces again.
I have done this because the Segmentation algo implementation returns a facet based property map.
Thanks to clarify.
On Mon, Sep 5, 2016 at 4:18 PM, Sebastien Loriot (GeometryFactory) <> wrote:
Could you provide a full example reproducing the issue?
Thanks,
Sebastien.
On 09/02/2016 07:24 PM, Sukhraj Singh wrote:
Hello,
I am trying to create a particular segment (which is the output of
surface mesh segmentation) as ROI in Surface Mesh Deformation.
I implemented following code, which is crashing( psb comment below)
void  set_all_vertices_as_roi()
     vertex_iterator  vb,  ve;
     for(boost::tie(vb,  ve)  =  vertices(*polyhedron());  vb  !=  ve;  ++vb)
       insert_roi_vertex(*vb);
//Implement it likewise all mesh vertices as roi
   void  set_segment_vertices_as_roi(Polyhedron  mesh)
     std::size_t  number_of_clusters;
     double  smoothing_lambda  ;
     //  create  a  property-map  for  segment-ids
     typedef  std::map<Polyhedron::Facet_const_handle,  std::size_t>  Facet_int_map;
     Facet_int_map  internal_segment_map;
     boost::associative_property_map<Facet_int_map>  segment_property_map(internal_segment_map);
//Run the sdf segmentation algo
     int  nb_segments  =  SegmentPolyhedron(segment_property_map,number_of_clusters,  smoothing_lambda  ,mesh);
     std::vector  <Polyhedron>  PolySegments;
     PolySegments.resize(nb_segments);
//Get the segement of the mesh
     GetSegments(mesh,segment_property_map,nb_segments,PolySegments,0);
//Make zeroth segment as ROI
     for(boost::tie(vb,  ve)  =  vertices(PolySegments[0]);  vb  !=  ve;  ++vb)
       //std::cout  <<  __LINE__  <<  std::endl;
         insert_roi_vertex(*vb); // GIVES CRASH
Perhaps it is because of size of deform_mesh, which was  equal to
complete non-segmented mesh size. ?
There is k-ring selection as well, which is used when picked by mouse.
Can someone suggest me some other way maybe, so that I could make the
mesh segment as ROI
Thanks to provide input.
Sukhraj Singh
Sukhraj Singh
