cgal-discuss - Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
  • To:
  • Subject: Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
  • Date: Wed, 7 Sep 2016 10:40:38 +0530
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Please find the Surface Mesh Deformation Plugin Code having the changes as attachment.
I think you should be able to find my changes using some code comparison tool. Else let me know.
It is based on 4.8.1 tag.
A function which is worth noting is as below. In which I get the crash.
//Implement it likewise all mesh vertices as roi
  void set_segment_vertices_as_roi(Polyhedron mesh)
    std::size_t number_of_clusters;
    double smoothing_lambda ;
    // create a property-map for segment-ids
    typedef std::map<Polyhedron::Facet_const_handle, std::size_t> Facet_int_map;
    Facet_int_map internal_segment_map;
    boost::associative_property_map<Facet_int_map> segment_property_map(internal_segment_map);
//Run the sdf segmentation algo
    int nb_segments = SegmentPolyhedron(segment_property_map,number_of_clusters, smoothing_lambda ,mesh);
    std::vector <Polyhedron> PolySegments;
    PolySegments.resize(nb_segments);
//Get the segement of the mesh
    GetSegments(mesh,segment_property_map,nb_segments,PolySegments,0);
    vertex_iterator vb, ve;
//Make zeroth segment as ROI
    for(boost::tie(vb, ve) = vertices(PolySegments[0]); vb != ve; ++vb)
      //std::cout << __LINE__ << std::endl;
        insert_roi_vertex(*vb); // GIVES CRASH
The approach I am following right now is, if you replace the for loop above with the below code. Also commenting the GetSegments() call, as it will not be required.
for(Polyhedron::Facet_iterator facet_it = (*polyhedron()).facets_begin(); facet_it != (*polyhedron()).facets_end(); ++facet_it) {
if(segment_property_map[facet_it] == segid)// the particular seg id I want as ROI
//Let's take the three vertices of facet
insert_roi_vertex(facet_it->halfedge()->vertex());
insert_roi_vertex(facet_it->halfedge()->next()->vertex());
insert_roi_vertex(facet_it->halfedge()->opposite()->vertex());
Thanks !!
On Wed, Sep 7, 2016 at 2:52 AM, Sebastien Loriot (GeometryFactory) <> wrote:
I see no error in this code, which is why a minimal example showing the pb would be great.
Sebastien.
On 09/05/2016 03:29 PM, Sukhraj Singh wrote:
Hi Sebastien,
  Instead of getting the segment polyhedron and using that to create an
ROI, I directly used the segment_map to create the ROI as follows.
I do get a correct ROI as seen form its vizulization, but have a doubt iterating in this way will push same shared vertex among faces again.
I have done this because the Segmentation algo implementation returns a facet based property map.
Thanks to clarify.
On Mon, Sep 5, 2016 at 4:18 PM, Sebastien Loriot (GeometryFactory)
< <mailto:>> wrote:
    Could you provide a full example reproducing the issue?
    Thanks,
    Sebastien.
    On 09/02/2016 07:24 PM, Sukhraj Singh wrote:
        Hello,
        I am trying to create a particular segment (which is the output of
        surface mesh segmentation) as ROI in Surface Mesh Deformation.
        I implemented following code, which is crashing( psb comment below)
        void  set_all_vertices_as_roi()
              for(boost::tie(vb,  ve)  =  vertices(*polyhedron());  vb
        !=  ve;  ++vb)
              int  nb_segments  =
        vb  !=  ve;  ++vb)
        Perhaps it is because of size of deform_mesh, which was  equal to
        complete non-segmented mesh size. ?
        There is k-ring selection as well, which is used when picked by
        mouse.
        Can someone suggest me some other way maybe, so that I could
        make the
        mesh segment as ROI
        Thanks to provide input.
        Sukhraj Singh
    <https://sympa.inria.fr/sympa/info/cgal-discuss>
Sukhraj Singh
Sukhraj Singh
Attachment: Surface_mesh_deformation_4.8.1++.tar.gz
Description: GNU Zip compressed data
