Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
- To:
- Subject: Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
- Date: Tue, 06 Sep 2016 23:22:05 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:aQO7Rx9SaeWSGv9uRHKM819IXTAuvvDOBiVQ1KB91ewcTK2v8tzYMVDF4r011RmSDNydtaoP07Ce8/i5HzdfsdDZ6DFKWacPfiFGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkJDD7+qQcuK04z3irjzqNXuZR5Vjm+9fa9qN0fx6h7As9Efx4pkMKc4jBXT5WBZfvxfgmJuK1XUlBn14oK8/YVo7j9L6M4mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKszEnX28fiQZJDg6NyBbgX5Dt+mvVu+141TWALOP/RqwzQyXjpe8/UxvvkiYAK3g89EnYj8VxiORQpxf39E83+JLdfIzAbKk2RajaZ95PGDJM
I see no error in this code, which is why a minimal example showing the pb would be great.
Sebastien.
On 09/05/2016 03:29 PM, Sukhraj Singh wrote:
Hi Sebastien,
Instead of getting the segment polyhedron and using that to create an
ROI, I directly used the segment_map to create the ROI as follows.
for(Polyhedron::Facet_iterator facet_it = (*polyhedron()).facets_begin();
facet_it != (*polyhedron()).facets_end(); ++facet_it)
if(segment_property_map[facet_it] == segid)// the particular
seg id I want as ROI
//Let's take the three vertices of facet
insert_roi_vertex(facet_it->halfedge()->vertex());
insert_roi_vertex(facet_it->halfedge()->next()->vertex());
insert_roi_vertex(facet_it->halfedge()->opposite()->vertex());
I do get a correct ROI as seen form its vizulization, but have a doubt
iterating in this way will push same shared vertex among faces again.
I have done this because the Segmentation algo implementation returns a facet
based property map.
Thanks to clarify.
On Mon, Sep 5, 2016 at 4:18 PM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Could you provide a full example reproducing the issue?
Thanks,
Sebastien.
On 09/02/2016 07:24 PM, Sukhraj Singh wrote:
Hello,
I am trying to create a particular segment (which is the output of
surface mesh segmentation) as ROI in Surface Mesh Deformation.
I implemented following code, which is crashing( psb comment below)
void set_all_vertices_as_roi()
vertex_iterator vb, ve;
for(boost::tie(vb, ve) = vertices(*polyhedron()); vb
!= ve; ++vb)
insert_roi_vertex(*vb);
//Implement it likewise all mesh vertices as roi
void set_segment_vertices_as_roi(Polyhedron mesh)
std::size_t number_of_clusters;
double smoothing_lambda ;
// create a property-map for segment-ids
typedef std::map<Polyhedron::Facet_const_handle,
std::size_t> Facet_int_map;
Facet_int_map internal_segment_map;
boost::associative_property_map<Facet_int_map>
segment_property_map(internal_segment_map);
//Run the sdf segmentation algo
int nb_segments =
SegmentPolyhedron(segment_property_map,number_of_clusters,
smoothing_lambda ,mesh);
std::vector <Polyhedron> PolySegments;
PolySegments.resize(nb_segments);
//Get the segement of the mesh
GetSegments(mesh,segment_property_map,nb_segments,PolySegments,0);
//Make zeroth segment as ROI
for(boost::tie(vb, ve) = vertices(PolySegments[0]);
vb != ve; ++vb)
//std::cout << __LINE__ << std::endl;
insert_roi_vertex(*vb); // GIVES CRASH
Perhaps it is because of size of deform_mesh, which was equal to
complete non-segmented mesh size. ?
There is k-ring selection as well, which is used when picked by
mouse.
Can someone suggest me some other way maybe, so that I could
make the
mesh segment as ROI
Thanks to provide input.
Sukhraj Singh
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Sukhraj Singh
- [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/02/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/05/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/05/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/06/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/07/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/07/2016
