- To:
- Subject: Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh
- Date: Wed, 6 Sep 2017 07:40:41 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:JCaIxxPWTEaWgA/IpFsl6mtUPXoX/o7sNwtQ0KIMzox0K/n5rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZFRz7cAZ0Pe/oAZX6jsKt1un09YeATR9PgW+caKh1KhD++RzIqs4SjI1vAqk0wxrN5HBPfrIFlitTOVuPkkOktY+L95l5/nEItg==
I misunderstood what collect_garbage() is there for. Thanks for the
clarification.
Best Regards,
IM
- [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 09/07/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/09/2017
