- To:
- Subject: Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh
- Date: Mon, 11 Sep 2017 17:02:02 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:zdshkRD5Kxc7V6XmWahrUyQJP3N1i/DPJgcQr6AfoPdwSP3zo8bcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERr2MU95J//+B5XJp8WxzeG7vZPJMCtSgz/oK4h/JhytsQTcsIEyhpFjLbp5ijTEpX5FZ/5H62pjOVWJjle2rpOr+Jl58iNM/fcl38FFWKT+Oa8/SOoLX3wdL2kp6Ziz5lH4RgyV6y5EXw==
Did you call CGAL::Euler::does_satisfy_link_condition() on the edge before collapsing it?
https://doc.cgal.org/latest/BGL/group__PkgBGLEulerOperations.html#ga2d19a3573640a9abb28885425bfd9f40
On 09/11/2017 10:37 AM, Iasonm wrote:
auto h_range = CGAL::halfedges_around_source(someVertex, m_M);
for (auto it = h_range.begin(); it != h_range.end(); it++) {
//or for(auto hei:h_range){
auto hei = *it;
the above code runs for ever and hei oscillates in the loop between two
values. This happens after I have collapsed several edges, consequently I
wonder whether by calling CGAL::Euler::collapse_edge I brake the mesh in
some way and the call to CGAL::halfedges_around_source returns a range
without an ending..
- [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 09/07/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/09/2017
