cgal-discuss - Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh
  • To:
  • Subject: Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh
  • Date: Wed, 13 Sep 2017 04:32:39 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23:RwSQRxdwGn/8HtXicj7yu9q9lGMj4u6mDksu8pMizoh2WeGdxc2/Zh7h7PlgxGXEQZ/co6odzbGJ4+a9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpW1aJhKqPgV8IqH5G5XZkt+s/+G04ZzaJQtS1xSnZrYnDRytqgPU/p0PmJdlLqs3xzPGp3JJf6JdwmY+dgHbpAr1+srlpM0ryC9Xof90r8M=
No I did not, but the thing is that a skeleton is not a 2-manifold surface
right? So maybe that's why edge_collapse was not used here
<https://github.com/CGAL/cgal/blob/master/Surface_mesh_skeletonization/include/CGAL/internal/Surface_mesh_skeletonization/Curve_skeleton.h>
. Maybe I should use a similar approach. Is there any doc regarding
Curve_skeleton.h or any document that describes its implementation (besides
the source code)?
Best Regards,
Iason
